12V into a 1995 OBS - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 05-31-2016, 05:58 PM Thread Starter
12V into a 1995 OBS
I have started a swap into my Ford F-350 1995. I am putting a 12 valve with bigger injectors, arp head studs, 60lb valve spring kit, afc kit, larger turbo, and 4k governor spring.
So far I have removed the 7.3l and will begin the install for the cummins. I will be using the stock transmission on the dodge as it already has a transfer case mated to it.
dirtrunner0519 is offline
post #2 of 6 (permalink) Old 05-31-2016, 08:41 PM Thread Starter
Re: 12V into a 1995 OBS
Anyone find away to use the stock tach sending unit in the cummins to work with the ford dash gauges or do I have to get that after market setup. I have tried to search and only found people using that after market gear with the sending unit.
post #3 of 6 (permalink) Old 06-02-2016, 04:16 AM
Justaworktruck
John Martens's Avatar
Aftermarket is what I used and it works good.
Pullinweight
1997 f250,03 cummins, HE351 turbo,van Aiken tuner, cobalt gauges, fass fuel,NADP 4r100, compushift tranny controller, air ride suspension, 05 axle swap, hydra boost upgrade
John Martens is offline
post #4 of 6 (permalink) Old 06-04-2016, 03:12 PM
Justaworktruck
Pullinweight
post #5 of 6 (permalink) Old 06-06-2016, 03:58 PM Thread Starter
How are you guys running the fuel lines. It seems like everyone has a different option or opinion. What are your guys opinions. Can I use the stock ford pump etc and just plumb it to the cummins or do I need a regulator etc. I got the motor in over the weekend
post #6 of 6 (permalink) Old 06-07-2016, 04:55 AM
Justaworktruck
As your truck has no in tank pumps (truck uses vacuum lift pump on engine) you need a lift pump, I used a fass. We have also used a superduty in frame pump w the fuel lab pressure reducer valve. Superduty pump puts out 80psi vs you need only 15-18psi. Fuel lab valve lets you turn it down. Fass or air dog do the same but cost a lot more.
Pullinweight
