Bronco II diesel swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 05-05-2016, 11:49 AM Thread Starter
tractorman1215's Avatar
Hey guys so I've been getting the itch to do a
diesel swap. I currently have my lovely OBS but I want something like a wrangler diesel. Since I'm a ford guy I thought why not a bronco 2 same wheel base as a wrangler almost same
size. My question is what motor is best I'm thinking like 7.3 or 5.9 I'd prefer 7.3 keep ford with ford but if I had to I would put a cummins in it. Also what else would need to be done axles suspension body modification etc. thanks guys.
tractorman1215 is offline
post #2 of 9 (permalink) Old 05-05-2016, 01:51 PM
Moderator
Sbluke55's Avatar
Re: Bronco II diesel swap
Those motors are huge. I don't think either one of them will fit. I would look into a 4bt. There is a thread here where a guy is putting one in a wrangler.
01 f-250, Standard
Sbluke55 is offline
post #3 of 9 (permalink) Old 05-05-2016, 04:40 PM
79jasper's Avatar
Or even a vw diesel engine.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #4 of 9 (permalink) Old 05-05-2016, 04:59 PM
Moderator
Sbluke55's Avatar
^^^^ that one would work too.
01 f-250, Standard
Sbluke55 is offline
post #5 of 9 (permalink) Old 05-05-2016, 07:42 PM
Because I can!!!
Thatchevyguy's Avatar
both 7.3 and 5.9 would be way to big. Ive seen a ranger with a 4bt but it had to have like a 3in? minimum body lift to clear the motor.
97 F350 cclb
7.3 5spd
95 f350 rclb 7.3
02 f350 ccsb 7.3
Thatchevyguy is offline
post #6 of 9 (permalink) Old 05-06-2016, 12:43 AM
"Slap hands slap hands"
FlossyB's Avatar
Also possibly a Toyota diesel the ones they put in the hilux are good diesel motors that would match well with a smaller vehicle like a bronco 2.
JB
FlossyB is offline
post #7 of 9 (permalink) Old 05-07-2016, 04:25 AM
ncovey's Avatar
Here you go,
https://kansascity.craigslist.org/cto/5561114150.html
1998 Ram 3500 Quad cab 12V 4x4 6 speed
1994 F-350 Cummins conversion project
ncovey is offline
post #8 of 9 (permalink) Old 05-09-2016, 02:40 PM Thread Starter
Alright what about a 75 bronco would that be a better fit for a bigger diesel swap? Basically what I'm looking for is something relatively small like a wrangler but can fit a bigger diesel like a 5.9 or 7.3.
post #9 of 9 (permalink) Old 05-09-2016, 02:47 PM
Moderator
Sbluke55's Avatar
Much better choice. Either one will do.
01 f-250, Standard
Sbluke55 is offline
