Cummins/5R110 Swap into E Super Duty - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 26 (permalink) Old 06-25-2015, 02:02 AM Thread Starter
I am wanting to replace the 460/E4OD in my 1996 E-Super Duty Bus with a 12 valve Cummins and a 2006 5R110 trans that I have. I understand that I will have to have a PCS controller and the 5R isn't the easiest trans to tune, but I think it might be a good setup if I can make it work. I hear it works best with the stock 6.0 computer, but that sounds like a real can of worms. Can anyone add any input about my plans?
dbshelton is offline
post #2 of 26 (permalink) Old 06-25-2015, 11:20 PM Thread Starter
Re: Cummins/5R110 Swap into E Super Duty
This maybe a crazy idea, but does anyone know just how tough it would be to use a factory computer from a 2006 E450 just to operate the 5R110 transmission? I know I would have to get a wiring harness and computer from a suitable donor. How would I find out exactly which circuits, wires, and sensors are required to operate the trans?
post #3 of 26 (permalink) Old 06-25-2015, 11:40 PM
Administrator
Zmann's Avatar
you might want to talk to the folks at DeStroked
but if shifting the 5r with just a 6.0 PCM was feasible you wouldn't need PCS controller for any swaps would you ? but you even need it for a cummins in to a 6.0 so ???
plus it needs a lot of input from the motor /cluster other sensors on the 6.0 remove the motor and you have issues
at least as far as I can guess but that's all I'm doing
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #4 of 26 (permalink) Old 06-26-2015, 02:04 AM Thread Starter
You are probably right. At first everyone needed a PCS with the swap and now with proper tuning some are making the OEM computer working with the 5R with better results than the PCS. Just thought I'd throw it out there. You never know.
post #5 of 26 (permalink) Old 06-26-2015, 03:46 AM
Administrator
Zmann's Avatar
I didn't know tuning could replace the PCS
see I learned sumptin ;-) thx
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #6 of 26 (permalink) Old 06-27-2015, 02:51 AM Thread Starter
Talked with 2 different transmission tuner guys today. One said using an 03-04 Ford PCM and SCT tuner to control the 5R trans will work very well, the other said he is pretty sure it will work. Sounds like a fun project. I think I'm gonna do this.
post #7 of 26 (permalink) Old 06-27-2015, 03:24 AM
Administrator
Zmann's Avatar
keep us in the loop !
DTR's Donation page
RIP DTR Ron
Zmann is offline
post #8 of 26 (permalink) Old 06-27-2015, 11:08 AM Thread Starter
Once I get started I will post it in this thread. Time to go parts hunting!
post #9 of 26 (permalink) Old 07-19-2015, 05:25 PM Thread Starter
Been getting stuff ready for the swap. Got my adapter plate and flexplate from DCS. Frame mounted the battery boxes underneath the body, made new cables and installed dual batteries (cranks over the 460 REAL well). Changed the rear gear ratio from 4.63 to 3.73. Also trying to gather up all of the misc. pieces to make the swap. I want to attempt to do all I can before the actual swap so it won't drag out too long. The goal is to spend about 4-8 weeks removing the 460 and E4OD trans, setting the 12v Cummins and 5R110 trans in place and building the motor supports, re-locating the trans crossmember rearward, shortening the driveshaft, fabbing radiator, trans cooler, and intercooler mounts and plumbing, and of course doing all of the wiring changes for the gauges, cruise control and transmission computer.
post #10 of 26 (permalink) Old 08-28-2015, 11:18 AM Thread Starter
I decided to wait for cooler weather before I tackle the swap. Finally found an 04 F350 wiring harness to use for the PCM. Gathered up all of the sensors that I will need. Still need to build the crank position sensor bracket, adapter to mount the larger TM-21 A/C compressor, and fab the turbo down pipe. I'll get those done in the next couple of weeks.
In the mean time, I have been sorting out the dual A/C system and driving the bus quite a bit. The 3.73 gears are a real improvement on fuel mileage and engine noise. It lost a very little acceleration, but all of the other pluses more than make up for that. Swapped in a diesel instrument cluster and programmed the speedometer.
