Another DT360 swap. 99 F550 CC Western Hauler - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 120 (permalink) Old 11-07-2014, 08:56 PM Thread Starter
Picked up a high mileage 99 F550 recently, knowing that it would either need some work, or a new engine. The truck had some serious running issues, lack of power, etc.
Diagnosed the issue to be a fueling issue, likely related to a failing fuel tank. Fortunately I had a fuel tank leftover from a 95 International School Bus that I was able to mount to the bed of the truck. Truck has been running strong since. Still has an up-pipe leak and one dead glow-plug. Going to fix the up-pipe with new donuts and replace the glow plugs, then drive it until I get all the parts together for the conversion and some time in the schedule to make it happen.
Truck is in great shape, interior is clean, it's an XLT so it's got some creature comforts. I added some side steps (for the wife), 2003 lights, tow hooks, a new stereo, did the foil mod to the door lock actuators, and just driving it now.
Used a VDO fuel sender, which reads the same OHMs as the factory sender, so the gauge reads properly. Also put a Racor pre-pump filter/water separator in.
Enough of that...
I recently purchased a DT360 and an Eaton FS5106A, and am starting the planning stages for the conversion. This is far from my first engine swap, I own a business that makes swap kits for Nissans, but this has me more excited than I've been in a long time. Still on the lookout for a 3.07:1 S135 center section, since this trans has a deep reduction first and no OD. With the 3.07 I'll have nearly the same reduction in first as I currently have in L with the 4:88's, and I'll have a better overall reduction cruising, for better economy.
While I'm waiting for the yard to pull the engine and trans, I've been studying Poopy's build, and making some plans. I designed my engine mounts, at least a preliminary design, will finalize once I get the engine here and take more measurements.
Unlike Poopy's 08, the 99 has a leaf sprung monobeam and a straight frame up front, so I should have a bit more clearance to work with. I plan on machining the mounts off of the DT's flywheel housing to give more cab clearance, and using the SAE bolt circle to mount the motor.
As they say, pictures are worth a thousand words, so I'll stop talking.
That's what I've got for now. Engine should be ready for pickup in a few weeks, I'll post pics when I get it home.
SuperHatch is offline
post #2 of 120 (permalink) Old 11-10-2014, 03:58 PM
Coastal's Avatar
Re: Another DT360 swap. 99 F550 CC Western Hauler
Wow you have all the fancy stuff! Should be an awesome project!
Coastal is offline
post #3 of 120 (permalink) Old 11-10-2014, 11:33 PM Thread Starter
Haha, years and years of collecting different tools for different jobs. My day job is an Engineer. so I go nerd from time to time.
I'm very excited about this project! I'll keep this updated with as much detail as possible.
post #4 of 120 (permalink) Old 11-11-2014, 03:39 AM
Freak'n know it all
gottagofast's Avatar
nice looking mounts tho I think the front one will need a bit more beef on the bottom
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead,
autometer gauges,
, South Bend HD clutch, Gen 2 wicked wheel, AIS intake system.
gottagofast is offline
post #5 of 120 (permalink) Old 11-11-2014, 04:55 PM Thread Starter
You're probably right. Once I get the motor in hand, I'll get final measurements and update the design from there. Thanks for the feedback.
post #6 of 120 (permalink) Old 11-23-2014, 08:07 PM Thread Starter
Picking up my engine/trans sometime next week. Will post pics once I get it. :)
post #7 of 120 (permalink) Old 01-05-2015, 08:21 PM Thread Starter
Well, I spent a lot of time searching for different steering wheel swap options for the early Super Duties, and nearly every thread I found talked about swapping in steering wheels with more controls, but the same overall design as the stock wheel. I found the stock wheel uncomfortable and ugly in my 99, and being a bit of a DIY guy, I decided to do something about it.
First step was to figure out what other vehicles used the same spline design as the early SDs. Then, look at some wheels and see which ones looked nice.
After a bit of research, I decided to purchase a 2004 Explorer wheel with airbag, clockspring, and pigtails for a whopping $100 shipped off of eBay. This wheel has the same spline design as the SD, but a much more modern look and a more comfortable feel.
I was hoping that the buttons on the wheel would function in the same way as the SD buttons, and I would simply need to splice the correct wires to make it all work. Unfortunately it was nowhere near that simple, but I did figure it out, and I wanted to share what I learned with the community.
I ended up opting to use the stock clockspring and wire the 04 buttons into the 99 plug. It was the easiest route, as you'll see below.
First, I want to explain how the stock buttons work on the early Super Duties.
As you can see in this diagram, the Light Blue/Black Stripe (LB/BK) wire is linked with both the GY/RD and DB wires through the cruise switches. Now in my truck, the GY/RD wire was actually Green/Orange. This wire simply goes to a chassis ground. When you push the buttons, this is what is transmitted through the LB/BK wire:
Coast - 120 Ohm resistance
Set/Accel - 680 Ohm resistance
Resume - 2200 Ohm resistance
Off - Direct to Ground
On - 12V Positive
Unfortunately, the 2004 Explorer, while having all the same buttons, operates very differently.
The cruise buttons are all linked together in the Explorer, and pushing any once button interacts with the others providing different resistances. Every function corresponds to a different resistance.
Coast - 300 Ohm resistance
Set/Accel - 600 (300+300 in series) Ohm resistance
Resume - 1110 (300+300+510 in series) Ohm resistance
On - 2110 (300+300+510+1k in series) Ohm resistance
Additionally, there is a 2.2k resistor that is always in the mix, so when nothing is being pressed, the output is the sum of all resistors in series, and when any one button is pressed, the 2.2k resistor acts in parallel.
Ok, all that sounds real complex and scary, so lets look at the actual Explorer switches. Each one has 4 wires going into it. A Green/Orange (Ground), a LightBlue/Black (Signal), a Red/Black (Illumination +), and a White/Red (Connects the two switches together).
Lets take the Coast/Set/Res switch all on it's lonesome. If you disassemble the switch you get this...
Pop the buttons off:
Remove the rubber insulator:
Remove the two T9 Torx screws and remove circuit:
There are 4 resistors in this image. Three for the cruise circuits, and one for the LEDs. I threw a multimeter on the LB/BK and GN/OR pins on the switch and started pressing buttons. If you pressed Coast, the output was 300 ohms, Set, 600 ohms, and Resume, 1100 ohms. Since the switch wasn't connected to the On/Off switch, the 2.2k resistor was taken out of the circuit.
Well then I did some simple math... Look at the list above for what the 99 cruise switch does:
So I mapped the resistors on the Explorer Switch:
I made a guess that the 300 Ohm resistor on the bottom was for the coast function, and the one in the middle was for the set function. I was right... I replaced the resistors with the following values. FYI, these resistors were all available at Radio Shack and are 1/8 Watt.
Now when you push each of the buttons on this switch, you get the resistances that the 99 wants!
Set/Accel - 680 (120 + 560 in series) Ohm resistance
Resume - 2180 (120 + 560 + 1500 in series) Ohm resistance (close enough to 2200)
With that squared away, it was on to the On/Off switch.
This proved much more challenging.
This is the On/Off disassembled
The first thing I did was removing the 2.2k resistor that was always in parallel with the circuit. I then removed the 1k resistor that was in series when the On button was pressed and replaced it with a direct connection.
This resulted in the LB/BK wire being connected to ground (GN/OR) when the Off button is pressed (what we want) and the White/Red wire being connected to ground (GN/OR) when the On button is pressed (not what we want)
We need to get the LB/BK wire to see 12V when the On button is pressed. First, we needed to sever the connection between the White/Red button and ground. This was accomplished by drilling through the trace at this point:
Now when the On button is pushed, the White/Red wire connects to nothing. We want to connect this wire to the LB/BK wire when pressed, so we can supply 12V to the White/Red wire and give 12V to the LB/BK wire when the On button is pressed.
I accomplished this by soldering a jumper wire on the backside of the switch between these two traces:
The front of the board looks all melty because I applied heat to the front side of the trace to solder the wire on the back, that way the plastic on the back didn't melt into my joint.
Now when the Off button is pressed, the LB/BK wire sees ground, and when the On button is pressed, the LB/BK wire connects to the White/Red wire. The last step is to notch the switch body to allow this wire to pass on the back side:
At this point you're probably thinking this is way too much work, but in reality I'm about 2 hours in at this point.
Now for the final wiring. I cut the clockspring connector off of the 99 button harness, and connected it to the 2004 button harness. I cut the 2004 Harness White/Red wire that connected the two switches together right at the Coast/Set/Resume switch since the two switches don't need to be connected together anymore. That wire will now go to 12V. Here are the connections...
99 Gray/Red to 2004 Red/Black - Illumination
99 Black to Nothing (this was a dedicated illumination ground, the 2004 LEDs share the switch ground)
99 Blue to 2004 White/Red AND Orange (12V to On button Switch and 12V to Horn Switch)
99 Green/Orange to 2004 Green/Orange
99 LightBlue/Black to 2004 LightBlue/Black
That takes care of the wiring, now lets talk about physically mounting the steering wheel.
Yes, the spline pattern is the same, but it is clocked differently. 90* off actually. So when the 04 wheel is installed, it is 90* turned to the left. This makes the 99 clockspring connectors try to come through the bottom of the 04 steering wheel frame. This seems bad, but it is actually ideal. With some simple modification to the 04 wheel, it can be made to fit easily.
I'll let the pictures do the talking, and for those without a bridgeport, just use a die grinder or angle grinder, this is just aluminum.
Test fit:
Trim the plastic:
Reinstall the plastic:
Install the wheel:
Install the buttons:
Ok, the wheel is mounted and the switches wired. The horn is the same plug and plugs right in.
Last, the airbag. The Explorer uses a two-stage airbag. Essentially the bag has two explosive charges in it. One fires for low speed impacts, both fire for high speed impacts. I wired the 99 trigger to the low speed bag charge. Some may opt to wire it to both, some may opt to not wire it at all. I'll leave this up to you and your philosophical choices.
Finished Product:
I recentered the steering wheel through adjusting the tie-rod. Road tested, all buttons work, illumination works, and no airbag light. If I get in an accident, I'll let you know if the airbag went off or not.
In my opinion it is a nice update to the truck and well worth the effort.
post #8 of 120 (permalink) Old 01-06-2015, 05:06 AM
96powerstroker's Avatar
Thats good stuff right there. Hopefully u update the looks inside & out too that way u have a stunning truck
96 F250 2WD, 286K, Built E4OD, 180cc Injectors, Tony Wildman Tunes, Beans Fuel System, 3in DP - 4in MRBP exhaust, CAI, 4:10LS SCLB, Traction bars,
62 F250 4X4, 223 I6, T98 4 speed, 4:56s RCFS (Reg Cab Flare Side. Factory) 31x10.50x15s, currently on 16in Alcoas
96powerstroker is offline
post #9 of 120 (permalink) Old 01-06-2015, 02:24 PM
Freak'n know it all
Not bad..... Nice insulator on the shifter too :)
autometer gauges,
post #10 of 120 (permalink) Old 01-07-2015, 03:51 AM
Coastal's Avatar
Hahahah the carhartt insulator mod!
Coastal is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.powerstrokenation.com/forums/28-engine-transmission-conversion/385193-another-dt360-swap-99-f550-cc-western-hauler.html
Posted By For Type Date
S130 Shop Truck Project | BinderPlanet This thread Refback 04-02-2016 02:27 PM
DT360 Into 1988 Ford F-350 cclb - Page 2 This thread Refback 01-12-2016 01:13 AM
DT360: The beginning - Page 5 This thread Refback 12-24-2015 08:34 PM
DT360: The beginning - Page 6 This thread Refback 10-31-2015 12:35 AM
