5.4 to 6.4 swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-27-2014, 06:07 PM Thread Starter
they call me tater salad
jawsfx4's Avatar
5.4 to 6.4 swap
hey guys i bought a rollover 6.4 that im currently putting into a 03 f250 that had a 5.4, my question is ive got the engine in the bay but the 6.4 mounts are too tall the engine sits way higher that the hood and there is about four inches of clearance between the oil pan and the cross member, does any body know of mounts i can use?
08 white cclb 4" straight pipe into 8'mitre cut black stack,dpf delete,egr delete,arp studs,6" fabtech lift,metal mulisha wheels wrapped im 37" toyos,sct running extremex,kenwood double din running two ten inch type r through a m1000,homemade front and rear bumpers, beamers hids
jawsfx4 is offline
post #2 of 7 (permalink) Old 10-27-2014, 11:16 PM
Re: 5.4 to 6.4 swap
6.0 mounts same as 6.4 will bolt right to block and have same crankshaft center line
Fixing ford diesels since before they had turbochargers
wise guy is offline
post #3 of 7 (permalink) Old 10-27-2014, 11:20 PM Thread Starter
jawsfx4's Avatar
Re: 5.4 to 6.4 swap
and they are shorter im guessing?
jawsfx4 is offline
post #4 of 7 (permalink) Old 10-27-2014, 11:47 PM
Re: 5.4 to 6.4 swap
6.0 mounts are totally different than 6.4.
When I mocked up my 6.4 in my 05 I puled the 6.0 the mounts bolted right to the 6.4 block and dropped it right into the 05 chassis fits just like 6 leaker. 03 is available with 6.0 simplest solution is use 03 6.0 motor mounts. just make sure to use correct 6.0 mounts for your chassis they are different 03-04 and 05+ bottom end is basically the same between 6.0 and 6.4 they use the same rear engine cover and lower oil pan
wise guy is offline
post #5 of 7 (permalink) Old 10-28-2014, 12:00 AM Thread Starter
jawsfx4's Avatar
Re: 5.4 to 6.4 swap
thanks thats awesome news! one other question, what did you do with the factory computer mount? on the 6.4 it mounts right in the firewall i was wondering if i should extend the wires and run it in the cab or not? and what about the heater box did you just keep it and plumb into it?
jawsfx4 is offline
post #6 of 7 (permalink) Old 10-28-2014, 12:24 AM
Re: 5.4 to 6.4 swap
Mine is a 2.6 sled truck I ditched the ac removed the evap core. heater hoses just ran bulk hose. kept the heat the truck has zf6 with sb triple disc , so it does not use tcm I swapped the 08 abs controller on to the 05 abs pump the 05+ truck have pcm hole in cowl panel so we just opened the hole up big enough for the 08 pcm. used stock 08 engine harness we made new harness from the old 6.0 pcm location to the 08 pcm for power ground and communication wires and a whole cluster f##k of wires for the anti theft and cluster ect... basically over laid the dash harness. Used the 6.0 battery cables and trays running electric fan 7.3 radiator & shroud we welded up the water outlets and IIRC used 6.0 radiator hoses. I have simi trailer full of powerstroke parts just dug trough the crap till found stuff that fit. mine is a single turbo manual cant imagine getting all the 6.4 stuff to work
wise guy is offline
post #7 of 7 (permalink) Old 10-28-2014, 04:59 PM Thread Starter
jawsfx4's Avatar
Re: 5.4 to 6.4 swap
ya its gonna be tight i think im might leave the ac alone for the winter but will move the pcm inside the cab ive got a few parts trucks here so i should be able to make it work
jawsfx4 is offline
