A slightly different DT360 Swap 2008 F450 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 6Likes
post #1 of 299 (permalink) Old 05-24-2014, 02:59 AM Thread Starter
Coastal's Avatar
Well the 6.4 slowly started dying a year or so back. It's still driveable, but I can't tow with it. Head gasket has a leak, it over heats under any load and pukes coolant...the usual.
I really like the motor, but the complicated electronics, and ram jammed engine bay aren't appealing to me. I had quotes to fix the head gasket, along with studs and whatever else they recommended and the quotes were from $6500-$10000. And it still has the original bottom end, HPOP, and whatever else might want to fail next.
I picked up a 1993 International 5 ton with a DTA360 for $1500, pulled the motor and have tentatively sold the truck for around $1000.
I didn't want to use an auto that might fail next, or spend $5-7000 building a tranny, so I've decided to stay medium duty. I picked up an International reNEWed Spicer ESO66-7b 7 speed tranny for $1500.
Next step is to divorce the factory T-case, and make this big blue beast fit.
I might have a forestry job coming up in a few months....so this thing has to get done in a timely manner....not another dreamer project, it's my only work truck so it has to get back on the road ASAP. Probably going to run the motor stock for now to save time and cost, then worry about making 4-500hp later.
Wish me luck!
Coastal is offline
post #2 of 299 (permalink) Old 05-24-2014, 11:13 AM
Re: A slightly different DT360 Swap 2008 F450
Good luck..Make sure and take a lot of pictures along the way.. Looks like i will be after Christmas starting my swap over.. Cant wait to ditch the 6.0!
navistar45 is offline
post #3 of 299 (permalink) Old 05-24-2014, 01:01 PM Thread Starter
Coastal's Avatar
I will for sure...I'd like to document everything complete with part numbers.
Not enough info on these swaps out there!
Coastal is offline
post #4 of 299 (permalink) Old 05-24-2014, 03:13 PM
whistle tits
ghohouston's Avatar
Very cool. Keep us updated
ghohouston is offline
post #5 of 299 (permalink) Old 05-24-2014, 06:28 PM
Vannnce's Avatar
has anyone else used one of those trannies in a swap into a pickup? I would imagine itd be sweet for towing, subscribed
2002 f350 Lariat 4" lift w/ 35's. DP tuned. Swamps 175/146 injectors. gauges. 5" turbo back exhaust
B&W turnover/ Companion 5'er
Vannnce is offline
post #6 of 299 (permalink) Old 05-24-2014, 07:55 PM Thread Starter
Coastal's Avatar
That Chansey guy used a Fuller FSO which is a very similar tranny in his dodge, if you look up FSO6406 on google, I think his threads have 90% of the hits...lol
I can't wait to tow with it. Towing with no worries....Good times! This particular tranny has a 50,000lb GVW rating at 660ft lbs of torque.
Coastal is offline
post #7 of 299 (permalink) Old 05-27-2014, 04:32 AM
Justaworktruck
John Martens's Avatar
Nice truck, like the big tires what size are they? By the looks of your trailer it's a Double A or Oasis.
Pullinweight
1997 f250,03 cummins, HE351 turbo,van Aiken tuner, cobalt gauges, fass fuel,NADP 4r100, compushift tranny controller, air ride suspension, 05 axle swap, hydra boost upgrade
John Martens is offline
post #8 of 299 (permalink) Old 05-27-2014, 04:46 AM Thread Starter
Coastal's Avatar
They are 40" Continentals on 20" wheels. I think that trailer might be a double A. :)
Coastal is offline
post #9 of 299 (permalink) Old 05-27-2014, 11:23 PM Thread Starter
Coastal's Avatar
I wanted to see how hard it would be to make this motor run out of the truck so I know what I am up against...
Apparently a battery, a Jerry can of diesel, a jump start and one wire.
Coastal is offline
post #10 of 299 (permalink) Old 05-27-2014, 11:33 PM
subd
2000 F250 ccsb 4x4. 218,000 miles, 38r 1.0 housing with turbo master, 238/80% FFD hybrids, BTS
riff raff FRx, Autometer C2 series gauges, DIY tymar, remote start, Hydra with GEARHEAD Tunes
lariat7.3 is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.powerstrokenation.com/forums/28-engine-transmission-conversion/347546-slightly-different-dt360-swap-2008-f450.html
Posted By For Type Date
6.4 to 7.3 swap? - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum This thread Pingback 04-28-2016 04:35 AM
Ski RV's, who's sleeping in parking lots? - Page 90 This thread Refback 04-08-2016 10:14 PM
S130 Shop Truck Project | BinderPlanet This thread Refback 04-02-2016 01:19 AM
Ford Fullsize Thread !!!! - Page 53 - Expedition Portal This thread Refback 11-20-2015 01:34 PM
DT360: The beginning - Page 6 This thread Refback 11-13-2015 03:08 AM
DT 360 and Allison trans - PowerStrokeArmy This thread Refback 11-01-2015 02:03 PM
DT 360 and Allison trans - Page 2 - PowerStrokeArmy This thread Refback 11-01-2015 12:33 PM
1989 F250 DT466 SWAP (With Lots of Pictures) - Ford Truck Enthusiasts Forums This thread Refback 10-29-2015 03:18 PM
6.4 truck swap to a navistar inline 6 dt360 - project - Page 2 - Ford Truck Enthusiasts Forums This thread Refback 10-28-2015 08:24 AM
