72 highboy 4bt.. VIDEO - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 05-12-2014, 03:35 PM Thread Starter
FlatbedRocketship's Avatar
Welll.. Started building another truck recently.
I built the 63 unibody 6bt that I posted last year.
Here is a teaser video..
Fummins - YouTube
Will post up pics and more specs later.
FlatbedRocketship is offline
post #2 of 8 (permalink) Old 05-12-2014, 03:39 PM Thread Starter
Re: 72 highboy 4bt.. VIDEO
Here is the build thread for the 63
63 F100 unibody Fummins conversion - PowerStrokeNation : Ford Powerstroke Diesel Forum
The 72 started its life with a 390, I was luck enough to find a 4bt with a ford transmission. Used the same factory trans mount, although had to put the mount below the shelf in between the frame rails and had to get a custom drive shaft. The ford trans has a park brake on the tail housing!
post #3 of 8 (permalink) Old 05-13-2014, 02:38 PM Thread Starter
I made my own motor mounts for this set up and I've got them blue printed so when the next one comes along it will be alot easier. Had to get a custom driveshaft made, from a 1330 u joint to a 1410, this was for the trans to t case.
post #4 of 8 (permalink) Old 05-13-2014, 02:52 PM
cpdad93's Avatar
what about the frame?
cpdad93 is offline
post #5 of 8 (permalink) Old 05-13-2014, 06:31 PM Thread Starter
What about it? I have not had to change anything frame wise in order for this to fit, the 4bt is actually alot shorter from front to back them the 390 was, so I have plenty of room between the cross member, I will have to flip the oil pan to be a rear sump because it is rather close to the front diff. Oil pan is symmetrical so all I will have to modify is the pick up tube.
post #6 of 8 (permalink) Old 05-13-2014, 07:02 PM
cpdad93's Avatar
I was thinking more of the frame rattling apart. I have seen a few try this with old Dodge 200s and the frames wouldn't take it.
cpdad93 is offline
post #7 of 8 (permalink) Old 05-14-2014, 12:00 AM Thread Starter
I guess time will have to tell on that one. The 6bt in my 63 hasn't caused a single issue with the frame, although it is on a 1988 frame from a f350..
I think she will be fine.
post #8 of 8 (permalink) Old 05-30-2014, 01:11 PM Thread Starter
Got the radiator mounted in last night, got the bumper back on..
All I need to do it get the lift pump on, the starter back in, wiring for the alternator, need to fabricate a braket for the hydraulic slave cylinder, need to run power steering lines and hook up some sort of vacuum for the brake booster.
So maybe another week or so. I will update with more pictures and videos later.
