1989 F250 PSD conversion - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 02-05-2014, 09:24 PM Thread Starter
I have an 89 250HD with a 351 and want to swap it out with a PSD, I recently purchased a complete 97 250HD as a donor truck and want to know what all will need to be changed out to go from my 351 up to a 7.3 any information anyone can give me is greatly appreciated!
Travis_89 is offline
post #2 of 2 (permalink) Old 03-17-2014, 11:43 PM
93-97 stroker
93-97 stroker's Avatar
Re: 1989 F250 PSD conversion
Everything from the seats forward. It's easiest to strip the wiring harness and everything out of the old truck and put your donor truck harness and dash in. I have a 93 idi that I did a psd swap and auto to manual swap and it went really well. Took a total of about 3 days and a few hundred dollars for parts(ie. glow plug relay, driveshaft work, and some other odds and ends). Pm me if you have any questions and I will try my best to answer them.
93 F250 ECLB was 7.3IDI auto replaced with 97 7.3PSD 5 speed, ARP main and head studs, Comp 910 valve springs, Smith Bros. pushrods, FF stage 2 (180/100) injectors, Adrenaline hpop, Irate T4 w/6.0 intercooler, S369sxe turbo w/.91 housing, diy e-fuel, quad pod w/pyro, boost, hpop and fuel pressure, Hydra w/custom tunes, 5 in. exhaust
93-97 stroker is offline
