7.3 obs died and no start. No smoke. HELP asap!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 01-24-2014, 04:23 AM Thread Starter
I have a 95 7.3l that was running great. Its decently cold here in alabama but the truck would crank easly around freezing. A bunch of dry roting fuel lines leaking i decided to do a few things
Pulled the tank and took the clogged screen out
Put tank back in. Replaced both fuel lines and bypassed the selector valve and ran fuel lines straight to fuel pump and return line
Pulled fuel bowl and fpr. Cleaned it all out
Put everything back together and filled the fuel bowl with seafoam
Turned truck on. Wts light came on as it should. Truck cranked and ran rough for a minute and died. Now itll turn over but not start. No smoke either
Good batteries. Fuel in bowl. New ford icp. No codes. Hpop res full. Oils good. Im lost. I need help asap. If someone would text me on my cell itd be way quicker respond. (Two-five-six) 654-1792
Alabama. 1995 7.3l powerstroke 4x4 automatic. Cold air intake. 5 inch straight pipe. Edge cs programmer. Bb mod.
Hunter_townson is offline
post #2 of 4 (permalink) Old 01-26-2014, 04:53 AM
kbmkviii's Avatar
Re: 7.3 obs died and no start. No smoke. HELP asap!!
Keep cranking you have a lot of air in the lines.
Hook up your charger.
The stock OBS fuel pump runs off the cam shaft.
You need to re prime it.
Keep filling the fuel bowl when it dies.
And are you sure you hooked the lines up right?
May be a stupid ? just something to consider.
96- PIS 350 200s. 76mm Billett GT4202R. Big Oil. Twin E-Fuel.
BTS. Sump. 140v IDM. Melling. Fluidamper. H11. VS. PR.
Auto Meter- Boost, Pyro, HPOP, Trans, Fuel.
HPOP/coolant/trans filters.
6.0 I/C and Trans cooler.
2012 SRT8 300 6.4
kbmkviii is offline
post #3 of 4 (permalink) Old 01-27-2014, 05:24 PM
matthewd11's Avatar
is the tach moving while cranking?
matthewd11 is offline
post #4 of 4 (permalink) Old 01-27-2014, 06:28 PM
moon__96's Avatar
keep watch on the WTS light I know it sounds simplistic but #22 fuse may blow during crankfest hope u get it spooolin
96 250 stock 160k miles $2k special drove it home
moon__96 is offline
