2000 f-250 fummins lights flickering - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 11-24-2013, 12:21 AM Thread Starter
So my truck started out as a v 10 truck it was a 5 speed now it has a 12 valve with a zf6 in it now. at idle the headlights and dash lights and cargo lights all flicker up and down I have a new alternator on it and voltage regulator on it any ideas on what else it could be brand new batteries as well do I need to put a 6.0 style alternator on it?
collinmaune is offline
post #2 of 8 (permalink) Old 11-25-2013, 02:58 PM
Re: 2000 f-250 fummins lights flickering
Its the external regulator. Been pondering doing something about it, but havent bothered to look into it much myself.
24v cummins swap into a superduty here:
brianell is offline
post #3 of 8 (permalink) Old 11-25-2013, 07:50 PM Thread Starter
I have changed the regulator a couple times and it still does it
post #4 of 8 (permalink) Old 11-25-2013, 08:01 PM
Sorry, meant its something with the regulator, not that its bad. Im wanting to find a way to clean up the electrical pulse, Ill let you know if I find anything.
brianell is offline
post #5 of 8 (permalink) Old 12-22-2013, 04:45 PM
Justaworktruck
John Martens's Avatar
You guys have good grounds? We have had were it needed a new frame ground.
Pullinweight
1997 f250,03 cummins, HE351 turbo,van Aiken tuner, cobalt gauges, fass fuel,NADP 4r100, compushift tranny controller, air ride suspension, 05 axle swap, hydra boost upgrade
John Martens is offline
post #6 of 8 (permalink) Old 03-26-2015, 01:07 AM
Looking to do this same swap to the same truck... pm sent
jawd is offline
post #7 of 8 (permalink) Old 03-26-2015, 01:20 AM
<---Peggy Sue
moose7.3IH's Avatar
Does it do it all the time? Does it have the grid heater?
e99 f350cclb lariat 4x4 zf6 ranchhands
leveled
4" dp 5" straight pipe
ccv mod
cai
Rosewood 180/100 single shots
Terminator t500 hpop
Garrett 38r with all the late 99 goodies
Currently
79 bronco 400m c6 8" lift 5.13s welded rear Detroit locker up front 38.5" tsls for the trail 35" bogger/buckshots for the mud bogs
moose7.3IH is offline
post #8 of 8 (permalink) Old 03-30-2015, 01:14 AM
Coal Blower
LORDDiESEL's Avatar
its the grid heater pulling 90 amp.
LORDDiESEL is offline
