IDI to Powerstroke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 11-22-2013, 01:17 AM Thread Starter
IDI to Powerstroke
Hello, this is my first post here. I have done some searching around but didn't find exactly what I was looking for yet. I hope I am not duplicating an existing topic.
I am the 2nd owner of a mint condition 1990 F250 with a ZF5 and a non turbo 7.3idi. I just picked up a 1994.5, 7.3 Powerstroke ZF5 F350 complete running donor truck. I am not too worried about the swap other than a couple questions on wiring, I would love to keep my original dash, is there a way to make the IDI tachometer read correctly from the Powerstroke harness? If not, is there an aftermarket tach that I could use?
bluestreak04 is offline
post #2 of 2 (permalink) Old 03-17-2014, 11:56 PM
93-97 stroker
93-97 stroker's Avatar
Re: IDI to Powerstroke
Are you wanting to keep the whole dash or just the outer shell(the part you see)?
93 F250 ECLB was 7.3IDI auto replaced with 97 7.3PSD 5 speed, ARP main and head studs, Comp 910 valve springs, Smith Bros. pushrods, FF stage 2 (180/100) injectors, Adrenaline hpop, Irate T4 w/6.0 intercooler, S369sxe turbo w/.91 housing, diy e-fuel, quad pod w/pyro, boost, hpop and fuel pressure, Hydra w/custom tunes, 5 in. exhaust
93-97 stroker is offline
