2008 f350 6.4 blew the motor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 10-30-2013, 07:31 PM Thread Starter
I blew the motor in my 6.4 what would be the best motor to drop in it for power and a long life how much would it cost to put a 5.9 in it or could I put a ford 6.7 in it any help would be nice
Sglass57 is offline
post #2 of 22 (permalink) Old 10-30-2013, 08:35 PM
they call me tater salad
jawsfx4's Avatar
Re: 2008 f350 6.4 blew the motor
a 6.7 would be cool but i imagine the tag on one of thoses would be close to 10k
if it were mine i would just drop another 6.4 in it properly maintained it will last a long time
08 white cclb 4" straight pipe into 8'mitre cut black stack,dpf delete,egr delete,arp studs,6" fabtech lift,metal mulisha wheels wrapped im 37" toyos,sct running extremex,kenwood double din running two ten inch type r through a m1000,homemade front and rear bumpers, beamers hids
jawsfx4 is offline
post #3 of 22 (permalink) Old 10-30-2013, 08:52 PM Thread Starter
I changed the oil ever 3000 miles tho and the tag on them are about 12 installed
Sglass57 is offline
post #4 of 22 (permalink) Old 10-30-2013, 09:02 PM
I'd put another 6.4l in or sell it
Dieseloutlaw270 is offline
post #5 of 22 (permalink) Old 10-30-2013, 09:51 PM
You could do a 5.9 swap but that might be a outrageous cost for all the parts motor PCM wire harness etc. I would drop another 6.4 in or sell. My friend had 80,000 on his 6.4 blew it put a new engine in ARP studs head gaskets injectors Elite Diesel Tow Power X turbo(S) EGR Delete with waste gate AFe intercooler. Guess what it blew again. The culprit #8 injector hung open and fried #8 Cyl still runs but its running on 7 cylinders.
Powerstroke Man 6.4 is offline
post #6 of 22 (permalink) Old 10-31-2013, 02:42 AM
jawsfx4's Avatar
the 6.4 is a good engine you always hear more about the bad than the good but that goes for anything but there are things have have a run of bad luck all you can do is properly maintain and address issues when they happen the reast is out of your hands, drop another 6.4 delete everything stud it and tune it you will be very happy. #### happens hopefully your next engine will last
jawsfx4 is offline
post #7 of 22 (permalink) Old 11-02-2013, 01:46 AM
spence_08's Avatar
light a match and walk away
08 superduty 6.4 fx4 sct live wire 9625or edge evo monitor flow pro 5 inch downpipe back. Afe stage 2 cold air intake 35 inch mickys on 18 revolver rims. dpf delete ccv mod
01 TDI jetta . Strait piped runnin on B100 summertime and B50 in the winter.
DRIVE IT LIKE YOU STOLE IT !
spence_08 is offline
post #8 of 22 (permalink) Old 11-04-2013, 03:50 AM
Justaworktruck
John Martens's Avatar
Ours did the same thing. Wouldn't buy another 6.4l. If the itch is there go with a CR cummins, I believe a 6.7 cummins has been done with good results. Conversion will run you 15k plus or 10k to do it yourself (approx).
Pullinweight
1997 f250,03 cummins, HE351 turbo,van Aiken tuner, cobalt gauges, fass fuel,NADP 4r100, compushift tranny controller, air ride suspension, 05 axle swap, hydra boost upgrade
John Martens is offline
post #9 of 22 (permalink) Old 11-04-2013, 01:42 PM
stroked99_1/2's Avatar
Injector hang open and melt/crack piston or did it spin bearings?
Renegade Diesel
stroked99_1/2 is offline
post #10 of 22 (permalink) Old 11-07-2013, 03:07 AM
Justaworktruck
Melted a hole in the piston,
Pullinweight
