wstarted the V10 to 7.3 project over the aeekend - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 32 (permalink) Old 10-15-2013, 02:19 AM Thread Starter
2000f350v10's Avatar
Well, I started my drivetrain swap over the weekend. Pulled out my triton v10 and I'm installing an international 7.3 from a bus. Getting a trans built as we speak (internals were the same from v10 to diesel) got complete engine and dash harness, ecm and idm from a member here. Just ordered new oil pickup, oil pan, oil cooler, and motor mounts. Hoping to drop the 7.3 in this weekend so I can start the wiring. Will try and take pics along the way. The v10 drivetrain came out very easily, so not many pictures. Wish me luck!
2000 f350 super duty 4x4. Leveling kit. 18" eagle wheels 35" tires. Originally a V10 now powered by an international 444 from a school bus. Billet converter. 2005 headlights. 4" turbo back exhaust. TS 6-pos chip. Non ebpv pedestal. Rosewood stage 2 injectors.
2000f350v10 is offline
post #2 of 32 (permalink) Old 10-15-2013, 02:24 AM
dsberman94's Avatar
Re: wstarted the V10 to 7.3 project over the aeekend
But is the bell housing the same from the v10 to diesel? If I remember correctly. No they aren't however from a bus might be different.
02
F250 7.3 Crew Cab Short Bed Lariat
4"dp 5 inch pipes to dual 8 inch stacks (summer)
4" turbo back dual axle dumps (winter)
PHP Hydra (loaded)
Edge insight CTS monitor w/ eas system
17 ton d-ring with solid polished titanium hitch
80% over rosewood injectors
Transgo tugger kit
dual disc tc
GTP38R
More to come
call me dan
dsberman94 is offline
post #3 of 32 (permalink) Old 10-15-2013, 01:03 PM
jtgf250's Avatar
Good to hear man. If I left anything out just hit me up and I'll get it to ya or if ya need any help.
2003 F-250 CCLB 7.3L
4" lift and PMF traction bar/block setup running 35s on 20x12s. Intake, exhaust, PHP Hydra w/ Gearhead tunes, gauges
2005 F-350 CCLB 6.0L
6" lift on 20x10s and 37s, studded, deleted, Powermax and Livewire with Quicktricks tunes, exhaust, intake (Wife's Truck)
jtgf250 is offline
post #4 of 32 (permalink) Old 10-15-2013, 04:16 PM
ToMang07's Avatar
Nope, they aren't. He'll need a 4r100 from a diesel to mount on the T444e.
~Tom~ 02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, PHP Phoenix-(STK-80dd-100P-120R-65T-40T) 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, Fisher 8' MM2. Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, Hutch/Harpoon, RR-Plenums/clamps, 203*TS and Billet Housing, ELC, Fumoto, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing...~AE w/Ford Pack~
ToMang07 is offline
post #5 of 32 (permalink) Old 10-16-2013, 01:36 AM Thread Starter
I have a trans from a diesel. But it was just a case. So I'm using the guts from the v10 trans in a 7.3 case. I shouldve said that earlier
post #6 of 32 (permalink) Old 10-16-2013, 02:19 AM
dsberman94's Avatar
Yes you should have. Haha. Well good luck. I will be following.
02
PHP Hydra (loaded)
Transgo tugger kit
dual disc tc
GTP38R
More to come
call me dan
post #7 of 32 (permalink) Old 10-16-2013, 03:07 AM Thread Starter
Guess i need to read over my posts. Haha. Damn smart phone! I'm also going to be using moroso one piece oil pan gasket on my build. That should be in thursday along with motor mounts and brackets.
post #8 of 32 (permalink) Old 10-22-2013, 12:03 AM Thread Starter
Had some good progress the last few days. I found out that to bolt the motor mounts on I needed a truck oil cooler not a bus one and to use the truck oil cooler I needed a truck exhaust manifold because the truck oil cooler hits the manifold. So I now have motor mounts on, new oil cooler using super duty truck ends, anr got a new dorman drivrs side exhaust manifold. Whew. Now the 7.3 is ready to drop in the truck. Hopefully dropping it in tomorrow night and then the slow process of wiring.
post #9 of 32 (permalink) Old 10-23-2013, 10:33 AM
97-7.3powerstroke's Avatar
Do you have the fuel system figured out? I'm sure the vacuum for hvac is different as in how its all hooked up to the electric pump. Does your truck have hydroboost on it already or did the v10 trucks have a brake booster. As well as the cooling system is all different and the front drive accessories on the motor. Just some ideas if you haven't thought about them yet.
97-7.3powerstroke is offline
post #10 of 32 (permalink) Old 10-24-2013, 01:52 PM
Bobs 7.3
Bobs 7.3's Avatar
Id lean away from the oil pan gasket as many are having problems with them leaking and never sealing rite. Id go with the gray stuff from ford instead of having to repull the same engine just because of a oil gush that wont stop.
Bobs 7.3 is offline
