Anyone ever build a dt530???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 09-30-2013, 02:58 AM Thread Starter
robbs4525's Avatar
Lookin on info to build a dt530 for a pulling motor for my obs....horsepower, torque, costs, ect ect ect????
97' ECLB-custom fuel system, F8- Jonothons Tunes, water/air, s475, gen 3, colt cam, bd idm, 300/400s, boost, honey badger, gen 3, pyro, trans gauges, bts, built motor and more
99 cclb dually, f8, exaust, intake, bts, stealth 1.1, 238/100s, 38r
robbs4525 is offline
post #2 of 10 (permalink) Old 09-30-2013, 03:30 AM
Billy Big Rigger
smoking69's Avatar
Re: Anyone ever build a dt530????
Where are you pulling that they let you use an engine that did not come in your truck originally?
The first question, Is it an E motor or mechanical? The mechanical engines are pretty much like a big 5.9 Cummins 12 valve, and most of the stuff works the same way. E motors use HEUI injectors just like 7.3's, so you'd look for 400/400 injectors, some sort of hpop and a fuel delivery system to keep up, find some custom head studs, some big turbos, and find what breaks, i don't know if the early 530 ecm's accept a 6 position chip like the 466's do. If i was doing a swap I'd do the 466 mechanical, everything you can imagine has been done with them and been built for 4000 hp on alcohol..it
97 F350, 300/200, GT4202R, Twin Walbro's, sumped F26E tank, built E4OD, ISSPRO gauges.
smoking69 is offline
post #3 of 10 (permalink) Old 09-30-2013, 03:41 AM
POWERSTROKEMIKE
Hypermax
powerstrokemike is offline
post #4 of 10 (permalink) Old 10-01-2013, 02:10 AM Thread Starter
robbs4525's Avatar
def. mechical......I just think it would be awesome to build one for a 2.6 pullin truck
post #5 of 10 (permalink) Old 10-01-2013, 02:15 AM
dsberman94's Avatar
You can pull with a truck with a motor in it that wasn't an option. You have to run in either open or unlimited. Only bad part is that those pulls usually start around midnight or don't run at all around here because it gets too late.
02
F250 7.3 Crew Cab Short Bed Lariat
4"dp 5 inch pipes to dual 8 inch stacks (summer)
4" turbo back dual axle dumps (winter)
PHP Hydra (loaded)
Edge insight CTS monitor w/ eas system
17 ton d-ring with solid polished titanium hitch
80% over rosewood injectors
Transgo tugger kit
dual disc tc
GTP38R
More to come
call me dan
dsberman94 is offline
post #6 of 10 (permalink) Old 10-01-2013, 02:56 AM Thread Starter
robbs4525's Avatar
so how do fords with 12 valves pull in the 2.6 class?
post #7 of 10 (permalink) Old 10-01-2013, 02:59 AM
dsberman94's Avatar
im saying open or unlimited like same class as the triple turbo fummins we have around. i just forget which class that is. i didn't say it was 2.6 though. just defending myself. youd have to read the rules
02
PHP Hydra (loaded)
Transgo tugger kit
dual disc tc
GTP38R
More to come
call me dan
post #8 of 10 (permalink) Old 10-01-2013, 03:05 AM Thread Starter
robbs4525's Avatar
Ok...well Im not asking or going to argue with you about rules across the country...Im asking if anyone has built a dt530 or 466, but thanks for your imput!
post #9 of 10 (permalink) Old 10-01-2013, 05:15 AM
Billy Big Rigger
smoking69's Avatar
There's a regular cab obs with a 466 built for pulling, dont know if hes on here though.Theres
post #10 of 10 (permalink) Old 10-01-2013, 11:06 AM Thread Starter
robbs4525's Avatar
Theres? haha it musta cut ya off!!
