Wiring for zf5 to E4OD Swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 09-23-2013, 07:04 PM Thread Starter
Yes, I want the auto. I found someone very willing with an auto truck to swap parts.
Think I got everything figured out except wiring. I know I need the auto pcm but what other harnesses need swapped beside obviously the tranny harness. I've heard that the underhood engine harness needs swapped, can anyone clarify?
03 F-350. EGR delete, ARP studs, BPD 7.3 fan clutch, coolant filter, cat delete, AT, 3.73s.
sg465 is offline
post #2 of 2 (permalink) Old 02-03-2014, 01:10 PM
Re: Wiring for zf5 to E4OD Swap
did you ever get any info on harness swap.im doing same thing ran into trouble no wts light/glow plug relay any help would be great
bigred1997 is offline
