2003 7.3 auto swap to a zf 6 speed need help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 09-15-2013, 06:15 PM Thread Starter
Got the trany swapped and shifts great and runs great but I can't get the 4 wheel drive to work and I can't get cruse control to work any suggestions ???? Do I need a different grant harnis ?? Or do I need to just jump wires ? I could really use help I'm getting dissapointed
Detlorsdiesel is offline
post #2 of 3 (permalink) Old 09-16-2013, 06:58 AM
JSchuricht's Avatar
Re: 2003 7.3 auto swap to a zf 6 speed need help
Does the 4x4 just not working in low range or is it all together dead? Also is it manual or electric? For the cruise, I would hook up a scanner and look at the inputs to see if the truck is looking for the old transmission to be in gear.
Also if you don't mind, I am in the middle of a swap too, do you know the thickness of the spacer between the engine and trans? Reason I ask is I can't find one anywhere and have seen four different thicknesses listed which makes it hard to make one myself.
JSchuricht is offline
post #3 of 3 (permalink) Old 09-17-2013, 09:15 PM Thread Starter
The 4wd is electronic and it is all together dead also the plate is 1/8 inch thick and that's I'm port ant because I left it out and stripped my starter bolts and my fingers are always touching the throw bearing any other questions u have feel free to ask
