6.4 to 5.9 common rail swap cost? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 07-11-2013, 11:52 PM Thread Starter
Powerstrokinfirefighter's Avatar
Just trying to find options for my truck. If the motor doesn't get replaced under warranty, I'm not so sure I want to spend the several thousands of dollars to replace the 6.4 Considered making it a fummins, but was seeing if anybody with knowledge on the subject had insight. Plan would be to keep the 5r behind it as its been trouble free. Any input is much appreciated
'94.5 F250, 7.3, SCLB, TS Chip, 6637 Intake, 267,000
'08 F250, 6.4, CCLB, deleted w/ Mini Maxx
'05 F350, 6.0, Six Speed, Lariat, 4" Magnaflow no cat, studded and deleted, Leveling Kit-SOLD
Powerstrokinfirefighter is offline
post #2 of 20 (permalink) Old 07-12-2013, 12:06 AM
Re: 6.4 to 5.9 common rail swap cost?
if your paying for it 20k and 5r will be questionable because you will need a stand alone trans controller and they don't work that good
wise guy is offline
post #3 of 20 (permalink) Old 07-12-2013, 02:36 PM
Depends. Are you doing the swap, have knowledge of swaps, and tools? Or paying someone?
If youre doing it, Ill bet you could do it for 5k, paying someone 15-20k.
24v cummins swap into a superduty here:
brianell is offline
post #4 of 20 (permalink) Old 07-28-2013, 11:05 PM
humpstowing's Avatar
Have a look at Destroked.com they make all the adaptors and have developed there own trans controler for the 4R and 5R auto's they have a list for what cummins to what ever ford trany you want to run
humpstowing is offline
post #5 of 20 (permalink) Old 07-28-2013, 11:13 PM
scott2001's Avatar
you be better off to just find a good used motor,. a lot less expensive.
2008 got a new flex pipe installed. S-b intake, 4in dp back exhaust, gear head tunes All deletes done now.
flow pro hot pipe. CCV mode.
2013 dodge charger
scott2001 is offline
post #6 of 20 (permalink) Old 08-08-2013, 04:10 PM
Coal Blower
LORDDiESEL's Avatar
5K wont cover all the parts by the time the dust settles. These swaps nickel and dime you to death.
LORDDiESEL is offline
post #7 of 20 (permalink) Old 08-08-2013, 04:27 PM
Id argue it can be done, just have to think a bit differently. Im under 2500 in my swap, including buying the ford to start with. 99 crew, 4wd, 24v 6speed.
brianell is offline
post #8 of 20 (permalink) Old 08-08-2013, 04:58 PM
Faster Than You
Eric@PTP's Avatar
Figure about 3-4 times the cost and a lot of future headaches than just swapping another 6.4 in there.
post #9 of 20 (permalink) Old 08-10-2013, 03:49 AM
Coal Blower
LORDDiESEL's Avatar
How? You mean cheap? Squeaky cheap? I never do anything in life that way. I do things the right way.
post #10 of 20 (permalink) Old 08-10-2013, 03:56 AM
Psd715's Avatar
Cost of swap - $10k-$20k & 1 man card.
'96 F-250 SCLB 4x4 Auto
3.5" dp 4" duals
Stealth dual hpop
Annd BIs on stock tuning.
Will
Psd715 is offline
