95 crew cab build - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 07-09-2013, 02:55 AM Thread Starter
95 crew cab build
Well I'm starting on a new project I picked up a 95 cclb pretty clean but has a 460 so I'm gonna swap a 7.3 from another truck I have that's just too rusty to fix got a lot planned on the way but want to get it in and running first so any suggestions are very appreciated and if anyone is in need of a 460 or the 4x4 e4od with it let me kno it runs decent and trans is very smooth also my diner truck is a reg cab will the interior harness plug in ? Pics will be up soon
Nick spends is offline
post #2 of 12 (permalink) Old 07-14-2013, 05:33 PM
STILL LEARNING
Bradbilt's Avatar
Re: 95 crew cab build
You will want the 460 truck t-case unless your donor is a F350
Bradbilt is offline
post #3 of 12 (permalink) Old 07-26-2013, 02:44 AM Thread Starter
Will that transfer case bolt up and will I b able to use the crew cab drive shaft ?
95 f250 eclb DIY intake straight piped and some tw tunes gauges and a d60
post #4 of 12 (permalink) Old 07-26-2013, 02:46 AM Thread Starter
At least it will match my other truck lol
post #5 of 12 (permalink) Old 07-26-2013, 12:39 PM
STILL LEARNING
Bradbilt's Avatar
To reuse the the 95 driveshaft, you will need a 92-95 1356 T-case
Bradbilt is offline
post #6 of 12 (permalink) Old 07-26-2013, 06:17 PM Thread Starter
Do I need to change tanks or just sending units ? And do I have to modify or change the trans crossmember or the front crossmember ?
post #7 of 12 (permalink) Old 07-27-2013, 01:18 PM
STILL LEARNING
Bradbilt's Avatar
Trans crossmember should be the same.
Yes, you need to modify the front crossmember(by putting in Diesel engine perches) and guys like to weld in a plate to fill in the gasser oil filter hole
They say Diesel eats galvanizing and the stick tanks are galvanized
Bradbilt is offline
post #8 of 12 (permalink) Old 08-01-2013, 01:15 AM Thread Starter
Well did a lot got 90 percent of the doner truck stripped out just wondering are the tank switch valves the same ? And how can I extend the fuel lines for the crew cab it's going in
post #9 of 12 (permalink) Old 08-03-2013, 11:54 PM Thread Starter
Think I got everything from the doner now on to the fun stuff new oil pan up pipes and manifolds as well as paint
post #10 of 12 (permalink) Old 08-03-2013, 11:55 PM Thread Starter
Engine and trans out in one shot with turbo on
