6.0 to '95 CCLB? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-17-2013, 09:26 PM Thread Starter
6.0 to '95 CCLB?
Hello,
I would like to put a 6.0 in a 1995 CCLB. Before you all say do the Cummins I have thought about it and NO. Want to stay Ford. The 6.0 with the proper MODs is awesome.
Question: Has this been done and how tricky is it.
Note: I have seen the YouTube video of the 1986 6.0.
Thanks
molṑn labé
2008 F250 4x4, 2.5" leveling kit, EGR/DPF/CAT delete, H&S MiniMaxx, H&S 4" Turbo back exhaust. HD300 tunes.
jhestness is offline
post #2 of 8 (permalink) Old 04-19-2013, 01:01 AM
not enoughsmoke's Avatar
Re: 6.0 to '95 CCLB?
Do it i want to see it
1999 F350 Fummins (lil blue)
1996 dodge megaton (Towing Chit)
1995 F350 Fummins (Under Construction)
1995 F250 lightning clone
1968 Fastback GT (Chillin In the Cave)
1987 Samurai (wishing It could tow)
not enoughsmoke is offline
post #3 of 8 (permalink) Old 04-19-2013, 01:18 AM
Banned
Glad to see you posted it here. That BS you got in the 7.3 section was pathetic.
I'll bump this for you.
miller45103 is offline
post #4 of 8 (permalink) Old 04-19-2013, 03:08 AM
I've seen one on YouTube doin a burnout and it was badass
97 f250 eclb e4od 4x4: p.i.s. 175/80s, built trans, obs/e99 hybrid turbo, t500, .20 over, afe intake, afe 4" straight pipe, comp springs, efuel, sd intercooler, isspro gauges, superchip 1705 because I can't decide between tony wild man or gear head for tunes....
blacksmoke powerstroke is offline
post #5 of 8 (permalink) Old 04-19-2013, 03:57 AM
iowacornfarmer's Avatar
This would definitely be a cool conversion. Do your self a huge favor and go on a place like erepairables or equivalent and find yourself a salvaged or damaged 6.0 truck for cheap and make your motor mounts and drop it in. Switch wiring harnesses and you could have it up and running. You may even be lucky enough to find a 6.0 that had updates done to it. Definitely a tough conversion but something to be damn proud of when finished.
1992 F350 RCLB - 12 valve Cummins - 7.3 intercooler - NV 4500 - M&H 4 fuel pin - 4407 T-Case - PMF 3.5 RSK - Fully LINE X'd - Tom Woods Custom Rear CV Driveshaft.
iowacornfarmer is offline
post #6 of 8 (permalink) Old 04-19-2013, 09:37 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Aww... a 6.0 driver doesnt like facts I see...
Sorry but its completely retarded to pull a 7.3 out of something and stick a 6.0 in there.
The OP seems to have this idea tht he is sticking with Ford, when in fact IH makes the motor in question.
but hey, what ever lets you sleep at night.
Joe
CSIPSD is offline
post #7 of 8 (permalink) Old 04-19-2013, 11:58 AM
Banned
If you dont have any good input on this, then do us a favor and go back to your 7.3 section.
The OP said what he wanted and stated specifically that he wants that.
A properly maintained and studded 6.0 is fine, but for some strange reason, a lot of 7.3 guys can't figure it out.
I'm not bashing the 7.3 by any means. I'm bashing the guys like you who call the OP stupid for an idea that's his. If you dont like it, dont comment.
Also, I never said anything about sleeping.
post #8 of 8 (permalink) Old 05-01-2013, 10:09 PM
Fixing Broken Stuff
toolmangary's Avatar
Cool swap, the wiring is going to be the biggest problem. Are you planning to run the 5R110?
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
