ZF6 SWAP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-21-2013, 03:37 PM Thread Starter
ZF6 SWAP
I'm needing info on what I'll need to do a zf6 swap..I found a great deal on a zf6 and manual case and need to know what ill need to go from the 5r to a zf..I can get harness teams t case pedals the works all the way down to the carpet but what will I need actually need to make this as painless as possible..will I need the pcm?? Column?? As of now I have full access.. please help..I'll be swapping a Cummins in also so that will come into play..also can I keep the electronic t case or would it be better to go with the manual..the manual case is included with the trans..
rjustman is offline
post #2 of 5 (permalink) Old 03-21-2013, 04:06 PM
Project20v's Avatar
Re: ZF6 SWAP
I vote manual T-case.
If you are doing a Cummins, just use the PCM you have. It will only control the cluster.
I recommend getting a manual trans hump.
I took my auto harness and chopped out the unneeded wires. You'll only need the T-case indicator, neutral safety and b/u circuits.
Early '99, 7.3/4R to Cummins 6.7/ZF6 CONVERSION, AIR LOCKERS, 4:11, 35", '05 HARLEY FRONT , TRAIL READY W/WARN.
6.7/ZF6 SWAP. IT'S ALIVE 11-13-12
Project20v is offline
post #3 of 5 (permalink) Old 03-21-2013, 09:37 PM
Re: ZF6 SWAP
Project20v, Can you point me to where you address the wiring for the ZF6 using the 5R harness? I am having some problem getting my truck to go into 4wd which I assume is due to the Neutral safety switch noting being addressed.
MikeHall is offline
post #4 of 5 (permalink) Old 03-22-2013, 12:42 AM Thread Starter
Re: ZF6 SWAP
Thx 20v..I sent you a pm the other day..
I actually have a 6.7 at home so may be mirroring your swap..I don't really wanna hack anything and the 6.0 will reside under the hood until sold..so I need it to work like factory for a while
rjustman is offline
post #5 of 5 (permalink) Old 03-23-2013, 04:42 AM Thread Starter
Re: ZF6 SWAP
well i purchased everything i think ill need to do the swap
steering column
clutch assembly
flywheel
PCM
floor hump
carpet
brake and clutch pedal
manual tcase
anyone think of anything else i may need??
also what would have been a good buy on all of this, just to make sure i didnt get bent over or pay to much
rjustman is offline
