Auto shifter removal - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-10-2013, 06:48 PM Thread Starter
splitshot's Avatar
Ive converted from an auto to a manual trans during my cummins conversion but have yet to remove the automatic shifter on the column, is there any tricks or tools to remove it and the wiring without destroying in case I someday decide to go back to an automatic?
2000 PSD crew 4x4
splitshot is offline
post #2 of 5 (permalink) Old 03-11-2013, 02:58 PM
Re: Auto shifter removal
I took mine out piece by piece. Not bad really. I did have to lower the column down to take the shifter off the top side of it. And took apart the cluster to eliminate the gear indicator. You will need about a 2" plug for the floor where the cable comes through.
24v cummins swap into a superduty here:
brianell is offline
post #3 of 5 (permalink) Old 03-11-2013, 04:23 PM
Freak'n know it all
gottagofast's Avatar
knock out the pin where the shift lever attaches under the boot and unplug the button. Get the plastic piece for a manual truck and leave the rest of the shifter parts in place.
I used krylon satin black to paint the indicator in my dash cluster or you can buy the part from ford and save your auto piece.
Last, cut your auto shift cable and pull the floor boot off of it... It makes the perfect place to run your wires and such for gauges to the engine compartment and you can buy a new shift cable if you ever go back.
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead,
autometer gauges,
, South Bend HD clutch, Gen 2 wicked wheel, AIS intake system.
gottagofast is offline
post #4 of 5 (permalink) Old 03-11-2013, 11:52 PM Thread Starter
splitshot's Avatar
Got it out, thanks guys. Now the only thing is the check engine light, Ive been told you can hit it with 12V, which wire would do the trick?
2000 PSD crew 4x4
post #5 of 5 (permalink) Old 03-12-2013, 02:52 PM
Project20v's Avatar
Just take out the bulb.
Early '99, 7.3/4R to Cummins 6.7/ZF6 CONVERSION, AIR LOCKERS, 4:11, 35", '05 HARLEY FRONT , TRAIL READY W/WARN.
6.7/ZF6 SWAP. IT'S ALIVE 11-13-12
Project20v is offline
