05 cr & 48re - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-01-2013, 08:10 AM Thread Starter
05 cr & 48re
Has any one swapped in a 05cr and 48re into a 02 f250? I need help with the wireing and any other useful hints to safe time on the conversion.
leeso is offline
post #2 of 7 (permalink) Old 03-01-2013, 03:38 PM
suprhlr's Avatar
Re: 05 cr & 48re
I did but I cheated and used painless wire harness. If you dont want to do it yourself you can send your harness to destroked and they will modify it for you. If you do end up doing it yourself your going to need lots of patience and good wire diagrams for both dodge and ford trucks
2000 f-450 suprhlr LA West conversion
04.5 fummins CR, twins by Engineered Diesel,
Hamilton cams, Exergy 40% injectors, 48RE suncoast/ Goerend converter PCS controller, airdog 2, smarty, 4.10 gears, 39k miles
suprhlr is offline
post #3 of 7 (permalink) Old 03-02-2013, 08:09 PM Thread Starter
Re: 05 cr & 48re
What did you do for the 48RE to get it working?
leeso is offline
post #4 of 7 (permalink) Old 03-03-2013, 02:43 PM
suprhlr's Avatar
Re: 05 cr & 48re
I'm running a PCS controller, a painless harness will not controll the trans
suprhlr is offline
post #5 of 7 (permalink) Old 03-08-2013, 10:24 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: 05 cr & 48re
Hows that PCS controller work out?
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #6 of 7 (permalink) Old 03-11-2013, 12:47 AM
suprhlr's Avatar
Re: 05 cr & 48re
I love it, it lets you controll your shift points to your personal driving
suprhlr is offline
post #7 of 7 (permalink) Old 03-11-2013, 02:35 AM
Fixing Broken Stuff
Re: 05 cr & 48re
How hard was it to get it working? The reason I'm asking is because I have a 24v and 5r110, and I'd like to use the two in a conversion. I have seen some posts that were not very positive on using the 5r110. Any advise? Thanks
2004 Jetta TDI
1956 F100
