Show me your battery set ups! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 01-02-2013, 03:42 AM Thread Starter
'm wanting to relocate or remove my passenger side battery on my 04 superduty and looking to see what everyone else did. I either want to get one big battery on the drivers side, two batteries, or relocate the second one to the frame rail or something. Show me your set ups with specs! Thanks everyone!
Sent from my iPhone using AutoGuide.com App
drmisherre is offline
post #2 of 27 (permalink) Old 01-02-2013, 02:26 PM
'05 Excursion
Term3's Avatar
I have a buddy that bought a Pelican case and bolted it under the bed of his truck for his batteries. Just remember to put vent holes.
www.pelican.com - Pelican Products Virtually indestructible cases.
Term3 is offline
post #3 of 27 (permalink) Old 01-02-2013, 02:30 PM
Project20v's Avatar
Re: Show me your battery set ups!
Not quite done yet.
Early '99, 7.3/4R to Cummins 6.7/ZF6 CONVERSION, AIR LOCKERS, 4:11, 35", '05 HARLEY FRONT , TRAIL READY W/WARN.
6.7/ZF6 SWAP. IT'S ALIVE 11-13-12
Project20v is offline
post #4 of 27 (permalink) Old 01-02-2013, 02:40 PM
in my build thread
fits 2 batteries. Tied another mount in to where the fuse box bolts as well.
24v cummins swap into a superduty here:
brianell is offline
post #5 of 27 (permalink) Old 01-02-2013, 02:45 PM
Originally Posted by brianell View Post
in my build thread
I love that!! where did you get that tray? or did you make it?
2000-7.3L is offline
post #6 of 27 (permalink) Old 01-02-2013, 03:37 PM
Built it, and every other part I needed to do my swap
With the dimples it makes the box very strong and rigid. Its only made from 20g, but I cant flex it at all.
brianell is offline
post #7 of 27 (permalink) Old 01-02-2013, 03:59 PM
docweld's Avatar
You did a great job on it!!!! I am going to do a dual under the pass side on the frame.
As of right now:
2000 F-350 7.3 Dually
6 speed manual
4:10 rear
DIY intake
DIY 4" exhaust
Hypertech power programmer 3
I am looking into new parts now, Turbo,sticks,custom tunes and all other supporting mods needed starting with fuel.
docweld is offline
post #8 of 27 (permalink) Old 01-02-2013, 04:01 PM
How much will you charge for one of these?
post #9 of 27 (permalink) Old 01-02-2013, 04:12 PM
If I could have at least 5 people lined up who would want one, I could get a quote together. To do one it just takes way too long. If I had 5 people wanting one, I could kind of justify doing a run of 10, and have the pieces laser cut, and cnc bent. Thats the only way to make it affordable. I have a couple laser cutters and form shops I use on a regular basis.
brianell is offline
post #10 of 27 (permalink) Old 01-02-2013, 04:19 PM
let us know! Love how clean it is
