Anybody running the ford a/c compressor on a 12v conversion? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 01-02-2013, 02:45 AM Thread Starter
Seems like a simple modification to the cummins bracket and I can run the Ford compressor. Would save some time making new lines and I wouldn't need to purge and recharge the system.
mustangracer42 is offline
post #2 of 11 (permalink) Old 01-03-2013, 05:15 PM
Re: Anybody running the ford a/c compressor on a 12v conversion?
I have seen several done that way or mock up a completely new bracket. But If your planning on it for the truck you got from me the ac has been bled off.
shafer171 is offline
post #3 of 11 (permalink) Old 01-04-2013, 12:20 AM Thread Starter
Yep. I realized it had been bled off. Just wanted to know for some of the others I'm doing. I like the idea of keeping the factory lines and pump though since the pumps are usually newer than the dodge ones on the 12valve motors I use.
post #4 of 11 (permalink) Old 01-04-2013, 01:45 AM
I think there are a couple threads on here of others etups doing this maybe they will post up.
post #5 of 11 (permalink) Old 01-04-2013, 01:48 AM Thread Starter
I searched. Couldnt find anything.
Getting the blocks, heads and cranks back from the machine shop next week. Then reassemble the motors and start putting trucks back together. Your old truck is second in the que.
post #6 of 11 (permalink) Old 01-10-2013, 03:54 PM
Most industrial 5.9's i have been around, run their compressor's off the corner of the head by the inj pump.. When i did the conversion on my Gmc, i used this location to mount the factory gm compressor[built my own mount].. I simply stacked a suitable pulley on top of the original 5.9's fan pulley to drive the compressor. Been working flawless for 4 years now..
navistar45 is offline
post #7 of 11 (permalink) Old 01-30-2013, 04:01 PM
i did same thing to mine its a 96 ford that had a 7.3 in it i used a 5 ribbed smog pump pulley of a gas moter and milled out the center to fit the fan pulley.
backlash is offline
post #8 of 11 (permalink) Old 02-01-2013, 01:52 AM Thread Starter
I just made a bracket that adapted the ford pump to bolt where the dodge one came from the factory.
Thanks for the input.
post #9 of 11 (permalink) Old 02-05-2013, 01:17 AM
is your truck a SD or OBS, I want to do the same but I think the frame will be in the way. Can you post a picture?
fummins97 is offline
post #10 of 11 (permalink) Old 02-05-2013, 01:23 AM Thread Starter
Mine is a Super Duty. I didnt take any. If i ever take the radiator off for anything, i'll snap a few
