installing 02 fummins into 97 obs, what will I need to change? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 12-23-2012, 06:18 PM Thread Starter
Justaworktruck
John Martens's Avatar
Pulling a CR out of a 2002 fummins SD along with 4r100 tranny. What will I need to change on the 97?
Pullinweight
1997 f250,03 cummins, HE351 turbo,van Aiken tuner, cobalt gauges, fass fuel,NADP 4r100, compushift tranny controller, air ride suspension, 05 axle swap, hydra boost upgrade
John Martens is offline
post #2 of 7 (permalink) Old 12-23-2012, 06:20 PM
whistle tits
ghohouston's Avatar
Re: installing 02 fummins into 97 obs, what will I need to change?
thats bad ass! you should post up some vids! of the 02 and the 97
ghohouston is offline
post #3 of 7 (permalink) Old 12-24-2012, 02:48 AM Thread Starter
Justaworktruck
Plan on doing a project on the build forum. Should turn out to be a good project. However need to do some prep work.
[color=gray]Sent from my iPhone using
Pullinweight
post #4 of 7 (permalink) Old 12-24-2012, 01:35 PM
whistle tits
ghohouston's Avatar
this is exactly what i want to do. i want to find a crew cab obs of some sort and an 03/04 cr engine to swap in
post #5 of 7 (permalink) Old 12-24-2012, 04:23 PM
Smoothcriminal
Smoothcriminal's Avatar
I also have had some interest in this. I have a 99 cummins, ive thought about takein the motor out an keepin for when the 7.3 dies, but then again I have a 53 block so figured it wasnt worth the time. Has 276,000 runs like a top. Still a good idea though for anyone that wanted to. I will keep tabs on this build!
1996 F-250
D60 swap, future plans 12v and nv4500
Smoothcriminal is offline
post #6 of 7 (permalink) Old 12-25-2012, 12:15 AM Thread Starter
Justaworktruck
Ok, I have the stand alone computer for the 4r100. The engine has a PCM that is NOT from a dodge.
Will the motor mounts fit?
AC pump, does it need to be relocated?
Engine has a cable throttle, will a gas job cable for cc work?
Planning to keep the batteries the way they are.
Planning on a BD exhaust brake, will valve springs need to be changed?
Sent from my iPhone using AutoGuide.com Free App
Pullinweight
post #7 of 7 (permalink) Old 12-27-2012, 03:20 PM
Some crack, some dont. There's more info out there to check out the 53 you have, with some measurements to see if yours is likely to fail or not. I think the measurement was .230 at the freeze plug between 3 and 4. Thicker, and no reports of cracked. I know of some trucks worked real hard, beat on, blowing up transmission etc, with 53's and no cracks.
24v cummins swap into a superduty here:
brianell is offline
