Anybody know how to make a 5r110 thinks its in park/neutral? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 12-14-2012, 05:18 AM Thread Starter
Still having issues getting the electronic shift transfer case to go into 4low after I did my cummins and manual trans conversion. Im sure its a function of the 4low safety features brake pressed, trans in neutral or park but since the 5r is all electronic, I cant seem o figure out which wires need to be looped to trick it.
mustangracer42 is offline
post #2 of 6 (permalink) Old 12-18-2012, 02:01 PM
me2
Re: Anybody know how to make a 5r110 thinks its in park/neutral?
You can figure it out from the shop manual.
However, if you put the shift selector arm in the park or neutral position, it will be in that gear.
If you disconnect all power to the transmission and put the shift selector arm in drive, the transmission goes into 5th IIRC.
New truck.
08 F350 King Ranch
Long box CC 4x4
6.4 5R110
Soon to get a Cummins 6.7 transplant.
Old truck.
Red '99 2WD F250 CC SWB
3rd gen 325/610 Cummins, ZF6
Custom air ride suspension
me2 is offline
post #3 of 6 (permalink) Old 12-18-2012, 04:54 PM Thread Starter
I should clarify why Im asking. I removed the 6.0 and 5r and put in a 12 valve and zf6. Im trying to get the esof into 4 low. I t doesnt know its in park or neutral.
post #4 of 6 (permalink) Old 12-19-2012, 08:17 PM
Project20v's Avatar
I don't know, do you have a wiring diagram? I would think that you bypassed the neutral safety in the trans harness, but apparently that did not do the trick, maybe it's just for the starting circuit. That is probably the case or else it would also try to shift when in park too. There must be something else too it. Sorry, mine is manual shift.
Early '99, 7.3/4R to Cummins 6.7/ZF6 CONVERSION, AIR LOCKERS, 4:11, 35", '05 HARLEY FRONT , TRAIL READY W/WARN.
6.7/ZF6 SWAP. IT'S ALIVE 11-13-12
Project20v is offline
post #5 of 6 (permalink) Old 12-28-2012, 10:07 PM
Fixing Broken Stuff
toolmangary's Avatar
Pin 21 on the transmission range sensor should be pk/wh wire with power on it, jump that to pin 17 bk/wh wire and it should think its in park.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #6 of 6 (permalink) Old 12-28-2012, 11:41 PM Thread Starter
Thanks. I'll give that a try on the next truck. I gave up on this one and put a manual shift transfer case in in it.
