fummins fuel problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 11-12-2012, 08:03 PM Thread Starter
A buddy of mine is doing the cummins swap in a 2000 f250. We have everything done, engine and trans all mounted, wired up new guages, completely ready to drive except for one problem. We cant get the fuel to stay primed. We can put the fuel line in a bucket and she runs great.when it goes to pull fuel from the tank(and yes there is fuel in the tank) it keeps grabbing air. We have been checking for air leaks. cant find anything.we've bled the line over and over and still cant hold the prime. anybody with any help/information/pointers, please let me know. thanks.
BJBOND is offline
post #2 of 6 (permalink) Old 11-13-2012, 12:36 AM
Justaworktruck
John Martens's Avatar
Re: fummins fuel problem
Not sure what your engine is but,
We had a common rail with a CP3 on it and it would idle, but as soon as we tried to speed up it would stall, changed CP3 and it still did the same thing. Finally found out about the small lift pump on the side of the engine was shot, bypassed it and she worked perfect.
Pullinweight
1997 f250,03 cummins, HE351 turbo,van Aiken tuner, cobalt gauges, fass fuel,NADP 4r100, compushift tranny controller, air ride suspension, 05 axle swap, hydra boost upgrade
John Martens is offline
post #3 of 6 (permalink) Old 11-13-2012, 05:20 PM
Betting youve got some restriction in the supply line. Does it have an in tank pump youre trying to pull through (originally a gasser)? You may be collapsing the line from suction, unusual but happens, Fittings on top of the tank bleeding air in? Id drop the tank down and start looking there. Maybe even try opening the gas cap, maybe youre creating suction from not having any breather on the tank.
24v cummins swap into a superduty here:
brianell is offline
post #4 of 6 (permalink) Old 11-13-2012, 09:49 PM Thread Starter
It's a first gen 12 valve with a ve injection pump. We'll try that. Any more help would be great too
BJBOND is offline
post #5 of 6 (permalink) Old 11-24-2012, 04:29 PM
Ever find anything?
brianell is offline
post #6 of 6 (permalink) Old 12-21-2012, 08:09 PM Thread Starter
injection pump iteself was bad. $870
BJBOND is offline
