E4OD to ZF5 Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 10-24-2012, 05:23 PM Thread Starter
LiftedREDStroker's Avatar
Will a ZF-5 out of a 1992 2wd 7.3L F-superduty bolt up to my 1995 4wd? Looking at doing a swap and I have two possible doner trucks both are F-supers one is a 92 the other is a 95 both are 2wd with ebrake on the tail shaft. Also are the frames different meaning is the F-superduty narrower than a f-350, somewhere I remember reading that cab chassie's are narrower but if anyone actually knows that would help. The 10 lug axels, did they ever make a 4x4 version? What would I need to do to set my D60 up to handle the 10 lug rims?
Jake Brown
1995 Ford F-350 4x4 CCLB, ZF5, Solid mass Flywheel, Banks Technicooler, DYI 6637, 3in downpipe, 5in exhaust, Isspro Gauges, MORE TO COME
LiftedREDStroker is offline
post #2 of 10 (permalink) Old 10-25-2012, 05:10 PM Thread Starter
Re: E4OD to ZF5 Question
Ok so from my research the from the front bumper to the back of the cab the frame is the same width, meaning motor and tranny stuff should swap over no problem.
Is there a difference between 2wd and 4wd zf5 cross members?
Jake Brown
post #3 of 10 (permalink) Old 10-28-2012, 11:34 PM Thread Starter
Anybody have any input? I havent gone up to measure so I do not know.
Jake Brown
post #4 of 10 (permalink) Old 11-07-2012, 07:41 PM
mxredneck's Avatar
I want to know this same info as i have a 1991 350 donor truck with a ZF5 I plant to swap in. I'd love to find a good write up about swapping in a ZF5 to an OBS and possibly a good parts list. PM me liftedredstroker if you have anything like that.
1996 F-350 CCLB dually, 4.10, 235/85R-16, ZF5, Tymar intake, Alabama Flowmaster, Isspro gauges, TS chip, Tightwad Mod
mxredneck is offline
post #5 of 10 (permalink) Old 11-07-2012, 10:04 PM
linkfarms's Avatar
Send a message via Yahoo to linkfarms
Should be plenty of write up's
You'll need drive shafts
pedals 87-91 pedals WILL NOT work in a obs or vice versa
and small wiring changes
superduty brick or obs 2wd zf's will work for 4wd's t-cases bolt right on with e-brake removed
swap is pretty straight Forward if you have both trucks right next to each other is best
Sent from my iPhone using Autoguide.com App
1995 f-250 xlt lariat 4x4 5sp 7.3 psd 4:10's chip stage 1's south bend clutch 300k miles and counting
past trucks 20+ diesels mainly idi's
linkfarms is offline
post #6 of 10 (permalink) Old 11-09-2012, 03:42 AM Thread Starter
did a google search this is what I found... I have not read the whole thing I only got a few pages into it... It sounds like no one has done a write up on it yet....
Transmission Impossible (E4OD to ZF 5 Speed Swap) - Page 2 - Ford Truck Enthusiasts Forums
Jake Brown
post #7 of 10 (permalink) Old 11-09-2012, 07:12 AM Thread Starter
Ok so I have read to page 14 so far... i havent seen any pictures yet (maybe because i am not logged in over there) but so far it is not a write up just a few hints and tips here and there. I will be looking into a parts truck soon and i will do a write up with pictures and we will post it here.
Jake Brown
post #8 of 10 (permalink) Old 11-12-2012, 09:49 PM Thread Starter
Ok so I am trying to work out a deal with the guy who is selling his 1995 F-SuperDuty. He has a CCSB F-250HD and needs a motor, long story short I hope to get everything I need for $1000 with a freshly rebuilt ZF-5. I will pull it apart to verify before it goes into my truck then refill will synthetic fluid.
Jake Brown
post #9 of 10 (permalink) Old 11-12-2012, 09:52 PM Thread Starter
New Question though, Does the PCM matter for 2wd or 4wd? The parts truck is 2wd, do I need to get a chip to make it run? or can I swap my E4od pcm with the ZF-5 PCM?
Jake Brown
post #10 of 10 (permalink) Old 11-27-2012, 07:44 AM Thread Starter
So $1500 later I have a ZF-5 and transfercase out of a 97, the flywheel, clutch, pedals, master and slave cylinder, and crossmember. I was suppose to get the PCM with everything but the guy ended up pulling the IDM instead. I am in the process of cleaning all the parts off with the steam pressure washer we have at work. So far I know I need to get... 1. New Fluid. 2. new seals on the sides of the transmission case. 3. new clutch.
Jake Brown
