6.0 to 7.3 swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 09-29-2012, 02:14 AM Thread Starter
6.0 to 7.3 swap
i was posting this for some opinions. ive done good with my 6.0 but love the truck and want to keep it for a long time. im so against putting a cummins in it, id put a 6.0 back in if i ever had too.
i started thinking, wouldnt a 7.3 be pretty easy? i have a 6spd... should bolt up there, i would change out cluster for a older model and use all the 7.3 electronics. hardest part would be the motor mounts and fuel system? so finding a donor truck would be kinda key
Nascar_fan28 is offline
post #2 of 7 (permalink) Old 09-29-2012, 03:28 PM
Proud PSN Sponsor
Deputydog's Avatar
Re: 6.0 to 7.3 swap
I could be done, but going to involve alot of electronics to make everything work right. If you're going to go thru all the expense and time of doing a conversion, just do it right the first time and put a Cummins in it.
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
post #3 of 7 (permalink) Old 09-29-2012, 03:33 PM
co04cobra's Avatar
Re: 6.0 to 7.3 swap
I have done a few. You need a 7.3 parts truck to do it the easiest and really the right way. Everything is there on a 6.0 cab and frame to put a 7.3 back in it. Also, your 6spd will not bolt up to a 7.3. The last one I did I left the 06 radio and dash required a little custom wiring but not much. If you switch EVERYTHING from a 7.3 parts truck its all pretty much bolt in.
Also, dont know what year your truck is, but you can leave your differantials. Leaf spring setups are all the same, and 05 up is easliy adapatable even with the 7.3 abs system.
00 f250 some stuff done always more to do.
Best advice I have seen on here "If you cant afford to build it right you certainly cant afford to build it twice"
co04cobra is offline
post #4 of 7 (permalink) Old 09-30-2012, 01:44 AM Thread Starter
Re: 6.0 to 7.3 swap
yeah i have a 05 truck. thanks for the input. thought the 7.3 ran the same 6spd, damn
post #5 of 7 (permalink) Old 09-30-2012, 04:36 PM
Here for the Ride!
devinferg's Avatar
Send a message via MSN to devinferg
Re: 6.0 to 7.3 swap
The bolt pattern on a 6.0 zf6 trans is way smaller than a 7.3 bolt pattern also the input shaft on a 6.0 zf6 is much larger than that of a 7.3.
1997 F350 Reg cab-Powerstroke 5 Spd 135k miles ts 6 pos chip diy k&n intake 4 inch exhaust autometer gs series pyro & boost gauges-SOLD
2001 F350 Reg cab- 7.3 powerstroke 157k miles Wicked Wheel 6 pos chip Full ATS transmission and 5 star converter 5" exhaust DIY traction bars ISSPRO gauges pyro boost and trans temp
devinferg is offline
post #6 of 7 (permalink) Old 12-06-2012, 07:31 PM
Re: 6.0 to 7.3 swap
plus you would be 80HP down in power stock to stock engines.
2006 Dodge 2500 MegaCab, 4x4, Auto, 5.9L CTD
SOLD-2001 F250 Lariat CC SB 4x4 auto, 207,000 miles, linex, DP tuner 40T, 80E, 120R. 3.5 inch DP/4 inch exhaust. ATS housing. AFE stage 1, Hutch and Harpooned, HV IDM. V-10 transmission cooler. Medium build transmission. Baby terminator single HPOP, Turbomaster wastegate, 1.0 exhaust housing.
tch.280 is offline
post #7 of 7 (permalink) Old 04-02-2013, 08:37 PM
co04cobra's Avatar
Re: 6.0 to 7.3 swap
I have swapped 7.3s into 6.0 trucks, but you really need a parts 7.3 truck to do it right. And most cost effective way.
Here is a better reply I had on most of what you need.
Swapping a 6.0l powerstroke for a 7.3l powerstroke - PowerStrokeArmy
