Desiel+used oil+gas - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 79 (permalink) Old 05-03-2008, 06:07 PM Thread Starter
psn browser
Desiel+used oil+gas
I am new to desiel trucks. I have always had jeeps and still do. This is what I am planning. I have a 110 gallon transfer tank in my truck. I want to mix 50 gallons used motor oil, 10 gallons 87 octane, and 50 gallons desiel. Am I pissing up a tree or is this a great plan. I have no interested in the vegy oil thing at all. So this is my plan. I have hundreds of used oil at my shop. Any thoughts are welcome.
Morning wood is offline
post #2 of 79 (permalink) Old 05-03-2008, 06:34 PM
Abrannan19's Avatar
Re: Desiel+used oil+gas
go for it..
Abrannan19 is offline
post #3 of 79 (permalink) Old 05-03-2008, 06:39 PM
My Detroit Diesel 6v92
dlonno's Avatar
Your emmissions will be off the charts.
dlonno is offline
post #4 of 79 (permalink) Old 05-03-2008, 06:45 PM Thread Starter
psn browser
I am gathering and biulding as we speak. I have a buddy with a body shop and thinking how to add paint thinner to the equation. As for the emmisions that is the reason I live in the Arkansas and not Cali.
post #5 of 79 (permalink) Old 05-03-2008, 06:45 PM
MPG Moderator
Dave Whitmer's Avatar
You will smoke like a steam locomotive if it runs at all.
Forget the gasoline. It just wrecks your cetane and the truck will run rough.
The used motor oil is OK, but you can't run that much without looking like yourrings/valve guides aare shot.
My advice: six gallons of filtered used motor oil and the rest diesel.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #6 of 79 (permalink) Old 05-03-2008, 07:09 PM Thread Starter
psn browser
I,m not as worried about MPG's verses just burning what is free and there.My trucks current and future mod,s are 6" lift,37" tires ,4.56, detriot lockers front and rear, over drive unit to be named when purchased, 2500-3000 lb's on the bed at all times.
post #7 of 79 (permalink) Old 05-03-2008, 09:45 PM
<<HowdoIgetridofthat
Imjosh's Avatar
I've got a buddy with a 24 valve that I think runs 10 gallons of used motor oil per tank in his truck.
It seems to run pretty good doesnt really smoke much or anything.
Figure thats about a 1/4 of the tank motor oil, maybe start there and add more until it just runs like ass.
02 F250 4x2 362rwhp/760rwtq
13.942 @ 98.44mph
Dp Tuner
Van Turbo w/ Wicked Wheel
Swamps 175/146
So this is how liberty dies. With thunderous applause.
Originally Posted by Big Bore View Post
John Wayne doesnt care where you watch his movies, and beer doesnt care where the refirgerator is.
Imjosh is offline
post #8 of 79 (permalink) Old 05-03-2008, 09:51 PM
<----Simply the best.
StrokerTurbo7.3's Avatar
Send a message via AIM to StrokerTurbo7.3
Have fun dumping all the oil in the tank when you fill up if you try 50 gallons
No longer a proud member of PSN.
StrokerTurbo7.3 is offline
post #9 of 79 (permalink) Old 05-06-2008, 12:34 AM
I did 2.5 gallons and it took like 15 minutes to dump that little bit... Also would a lil bit of waste Veggy oil work with out the convertion... specially during summer? What &#37; would you mix WVO with Diesel so that you can run no convertion?
99.5 F250 2wd 6Speed: DP Tuner, Straight Pipe, DIY Tymar, 203 Thermostat. Spec Focus Hauler!!
23.5 MPG (HIGHWAY)
17.5 MPG (City)
INFOCUSHAULER is offline
post #10 of 79 (permalink) Old 05-06-2008, 11:45 AM
I've got a 1,000 gal. skid tank full of B100 that I want to put in 100 to 150 gal of WMO. Will it mix by itself or will it have to be agitated? I have a 2 micron filter post pump on the tank + 2 micron on truck FASS system along with the water seperation filter on the FASS system. Is there anything else to consider if going this route? Putting in 150 gal WMO will reduce fuel cost about .44 cents per gal.
99.5 F-350 SRW 6 speed mods:PHP live tuned., MSD propane system, snow water injection,DDP stage 1 injectors,AFE stage II air intake,ITP boost regulater,3.5 turbo back exaust,FASS fuel system. Gulf Coast oil bypass filtration, ITP reg. return, HPX oil line , GTP 38r with 1.15,EBPV delete. 430,000 miles,Adrenaline HPOP
cantrellc123 is offline
