3:73 vs 3:54's? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-30-2008, 05:24 AM Thread Starter
Got 'Er Did
lownslow's Avatar
3:73 vs 3:54's?
checkin out randy's ring and pinion
I run nothin smaller than a 285/75/16
will changing my gears from 3 73's to 3 54's make that much differenc?
bein a 4wd 3 54's is the most i can change
2009 Mustang GT Premium 5spd
BBK Long Tube Headlers and Off Road X Pipe
waiting for the squeeze
1995 F350 Crew Long 4x4 Dually
Powerstroke
Auto
4 inch MBRP
lownslow is offline
post #2 of 4 (permalink) Old 04-30-2008, 02:13 PM
Deputydog's Avatar
Re: 3:73 vs 3:54's?
I doubt you would notice much if any gains in MPG. I would stay at 3.73's personally.
Deputydog is offline
post #3 of 4 (permalink) Old 04-30-2008, 05:16 PM
OBS junkie
Cat_Rebel's Avatar
Re: 3:73 vs 3:54's?
;whs: Figgure the cost vrs savings don't add up. Now maybe 4.10+ to 3.55 would be worth it. But just stick with the 3.73 it's a good all around gear.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #4 of 4 (permalink) Old 05-02-2008, 12:48 AM
MPG Moderator
Dave Whitmer's Avatar
Re: 3:73 vs 3:54's?
I do agree that 3.54s at this time are not really worth the expense. 3.54s will reduce your engine RPM by only 5%.
A better approach (especially for a 4x4) is to go with an overdrive. The Gear Vendor will reduce engine RPM by 22% and the US Gear will reduce RPM by 20%. Both are very durable in fact far more durable than Ford automatics but they are salty. Figure somewhere between $3,000 and $3,500 installed. The payback @ 4.00/gal is about 100,000 miles.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
