electric fans - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 02-14-2011, 12:09 PM Thread Starter
jdubb823's Avatar
electric fans
Is anyone running them? It seems like a no brainer to me when it comes to cutting down on drag. I would be worried about it getting to warm. Just seeing if anyone has or is planning on doing it. What type of gains they have seen. That sort of thing.
2002 F350 SRW CC
20x10 XD Hoss, 35's, 05 suspension and axle swap, 05 clear headlights with 55w 6k hids(for sale).
Project DUBBLUP
jdubb823 is offline
post #2 of 29 (permalink) Old 02-14-2011, 09:57 PM
MPG Moderator
Dave Whitmer's Avatar
Re: electric fans
Doubt if electric fans can pull air through three heat exchangers.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #3 of 29 (permalink) Old 02-14-2011, 09:59 PM
MPG Moderator
Re: electric fans
Ever thought of cleaning up the aero on that trailer?
That would be cheaper than fancy electro-mechanical mods.
Slammed 4"
Rugged Air Dam
315,000 miles
post #4 of 29 (permalink) Old 02-14-2011, 10:29 PM
Moderator
PsRumors's Avatar
Re: electric fans
I had them on a high horsepower trailblazer pulling through two trans coolers, two air to water heat exchangers and the radiator. I was using a single fan from a C6 Corvette.
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #5 of 29 (permalink) Old 02-14-2011, 10:56 PM Thread Starter
jdubb823's Avatar
Re: electric fans
The trailer is a V nose, with a slant on the V section to help down force on the back of the truck. Flex a lite has one listed for the 7.3 trucks. They claim 6% increase in mph. Not to mention 27hp... like I said claims.. I have switched out clutch fans for electric fans on other applications, but none of them as costly to repair as this if something goes wrong.
2002 F350 SRW CC
Project DUBBLUP
jdubb823 is offline
post #6 of 29 (permalink) Old 02-17-2011, 02:43 AM
GS247's Avatar
Re: electric fans
i looked into this a year or so ago. the stock fan flows somewhere around 10,000 cfm, and i never found an aftermarket fan that would touch it. i have a 6.0L though, im not sure about the 7.3
03 EB EXcursion 6.0L
AFE intake
Edge Juice W/Attitude (gauges only)
Glow Shift Oil, Coolant, & Trans temp gauges
SCT X3 w/ xtreme street from Innovative
MBRP 4" turbo back
ARP studs
Jefferson State Diesel Coolant Filtration System
FICM modded by Jefferson State Diesel
Slotted brake rotors (front)
Mag-Hytec trans pan
GS247 is offline
post #7 of 29 (permalink) Old 02-17-2011, 03:00 AM
Moderator
PsRumors's Avatar
Re: electric fans
I have never had my stock fan kick in over the year I've owned it.....my Dad says he never knew of the fan kicking in over the 12 years he owned the truck.
PsRumors is offline
post #8 of 29 (permalink) Old 02-21-2011, 03:50 PM
Midwestern4x4.com
lrazer's Avatar
Re: electric fans
my buddy has dual electric fans on his. he says he only needs to turn them on when sitting in traffic or stopped otherwise driving down the road he leaves them off.
03 Intl 4300 Dt466
16 F350 RC 4x4
10 Intl Durastar Dt466
15 F350 RC DRW 4x4
14 F550 CC 4x4
02 F250 CCSB 4x4 ZF6 Swap
-P.I.S. 160cc/30%, GTP38R, T500
-Regulated Return, DP Tuned
99 F550 RC 2x4 ZF6
01 F250 SCLB 4x4
-DIY Intake, 4" Exhaust
02 F250 SCSB 4x4
-AIS Intake, 4" Exhaust, DP Tuned
lrazer is offline
post #9 of 29 (permalink) Old 02-21-2011, 05:13 PM
Junior Mint
Re: electric fans
I have them on my truck. Honestly I don't tow heavy enough to comment on their effectiveness.
They barely ever come on.
I'm officially...Stroke-less.
Suns_PSD is offline
post #10 of 29 (permalink) Old 02-21-2011, 05:23 PM
Super Hauler!
Super_Hauler's Avatar
Re: electric fans
you should start "using" the truck then, i cant even get a mile from home pulling a trailer without the fan kicking on. right around 217* the fan should kick on!
Super_Hauler is offline
