8 mpg turning 1800 @ 70 ish..any tips - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 02-08-2011, 05:38 PM Thread Starter
Im getting horrible mpg in my 01 7.3 auto crew cab. It has a 3" lift on 35's.I drive it very conservative. Its got a fresh fuel filter, fresh air filter, always run standyne. The truck drives fine otherwise. I can't find any evidence of the brakes hanging up. Literally a 10 mile drive to work you can watch the fuel guage drop. Ill be lucky to get 110 miles on a half tank and its a 25gallon tank filling it to the top. Anyone have some suggestions?
AutomagicLS1 is offline
post #2 of 16 (permalink) Old 02-08-2011, 05:47 PM
FuturePharmD's Avatar
Re: 8 mpg turning 1800 @ 70 ish..any tips
Is it a sudden drop in mph? Any other mods, injectors, chip, gauges? You made sure tire pressure is up? I'm just thinking out loud, but what about the rpm's getting up to cruising speed? I get my best mpg keeping boost under 5 psi getting up to speed. What about your oil level?
2002 F250 ccsb Lariat 4x4
6637 intake
4" MBRP
Stage 1's by Full Force Diesel
Honey badger Jr hpop and Brute 66
Bellowed up-pipes and blank pedestal
No Limit Tuning by Jonathan (Dyno Proven)
Rough country level and shocks
305/70r16 Toyo AT2 on Dc2
Autometer factory match (pyro,boost,trans)
FuturePharmD is offline
post #3 of 16 (permalink) Old 02-08-2011, 06:23 PM Thread Starter
Truck is bone stock besides lift, tires and 4" turbo back exhaust. Oil level is fine. I bought the truck not to long ago and im wondering if this is why it was for sale but I want to find out. Tire pressure is about 45psi. It has a diablo predator I've tried th stock tune, towing tune and 80 hp tune and they all get about the same mpg with my foot out of it staying out of boost as much as I can
post #4 of 16 (permalink) Old 02-08-2011, 08:04 PM
secondarychaos's Avatar
predator and the lift are killing you. get a custom tune, or go back to stock.
Also, if you can bear it, slow down to 65. sounds small, but makes a noticable difference.
do you have gauges? specifically EGT?
Is your speedometer recalibrated?
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #5 of 16 (permalink) Old 02-08-2011, 08:07 PM
I keep my tire pressure around 60#. It sounds like something funky is up though. I know my mpg stinks when just driving around town stop and go even with me taking it easy. I average around 12 city with my setup.
6637 intake
4" MBRP
post #6 of 16 (permalink) Old 02-09-2011, 10:49 PM
MPG Moderator
Dave Whitmer's Avatar
Couple of things.
Check your EBPV. These things have a tendency to stick shut. Mine used to blow from September to May, so I electrically disconnected it. Gained 2 MPG during the winter.
Try re-booting your ECM. Disconnect the batteries and wait a minute or two, then reconnect. Sometimes the programming gets corrupted and some guys swear by a reboot.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #7 of 16 (permalink) Old 02-13-2011, 04:40 AM
Beef
keep the oil fresh and w/ sythetics in the winter.
even w/ the diablo i got 17 mpg w/ 35" XT's I could still ave 14-15 playing in the dunes. W/ some swamp tunes you might get a bit more.
Check that the up pipes aren't leaking, also if your HPOP isn't up to par or is leaking that will kill the mpg as well.
hows the compression?
good luck.
"New" 05 no payment, all original 305k and runs like a champ
powerlifter405 is offline
post #8 of 16 (permalink) Old 02-13-2011, 05:24 AM
im gonna follow this thread since im having the same issue with same mods basically. and gave up after tryin to fix it for the longest time.
Bockhold is offline
post #9 of 16 (permalink) Old 02-13-2011, 05:27 AM
stoker04's Avatar
What gears does your truck have? 1800 rpms seems a little low at 70mph
2004 F350 6.0 ECSB Lariat. All the normal stuff
stoker04 is offline
post #10 of 16 (permalink) Old 02-13-2011, 11:13 AM
with 35s, the speedo has been recal. mines 1800 at 70 as well. stock will put 70 at 2050rpm. i have 35s as well and thats my speedo reading.
i have 3.73 gears. 4.10s would be a lot higher.
Bockhold is offline
