Tire size vs. mpg - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 01-04-2011, 05:14 PM Thread Starter
Tire size vs. mpg
So I bought my truck with 305/70R16s on the stock 16" rims. They are LRC or D and actually have less load capacity thatn the OEM 265/75 LRE tires. They are the standard BFGoodrich AT tires. They are nearing the end of their life and I tend to overload the truck and like long tows with an RV so I want good tires. I have 3.73 gears and an auto.
The choice I have is between 285/75 and 265/75 tires.
My question is, what mpg differences can I expect to gain by downsizing to 285 or 265 tires. I have chosen the General Grabber HTS all season highway tires with "Low Rolling Resistance".
Are the 265s the ideal mpg tire?
2000 F350 SRW, 4wd, CCSB, PSD
Lowered rear end to F250 height, 4" exhaust w/ muff, foil delete, AIH delete, Ford AIS intake, tru-cool trans cooler, autometer under dash pod and gauges, Mile Marker hubs, 04 headlights, soft tonneau
18' 10k rated PJ car hauler
26' 7500# Creekside RV Trailer
Kioti CK30 tractor
Highbeam is offline
post #2 of 31 (permalink) Old 01-04-2011, 07:06 PM
Re: Tire size vs. mpg
When I went from 315s to 285s, I really didn't notice that much of a difference. Maybe a mile per gallon.
2000 7.3 F-350, PHP Tunes, 5" straight pipe, intake, gauges
forddieselkicksass is offline
post #3 of 31 (permalink) Old 01-04-2011, 10:11 PM
MPG Moderator
Dave Whitmer's Avatar
From what I can tell, either 265-75x16 or 235-85x16 are the optimum sizes for MPG.
Hey! One MPG for just tires is a nice difference.
Be sure and recal your speedo.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #4 of 31 (permalink) Old 01-04-2011, 10:16 PM
True, it does add up. But I didn't really pay attention to it because I'm not sure how much the odometer was thrown off by the bigger tires.
post #5 of 31 (permalink) Old 01-05-2011, 03:18 AM
My best mpg experiences have came from BFG rugged trails. Also, the wider tire will get worse mileage (the 285s) not going to affect it by much, but I'd say 1 mpg is a good estimate
'11 F250 Crew Cab Short Bed XLT FX4 Midnight Black
Wheels11 is offline
post #6 of 31 (permalink) Old 01-05-2011, 03:24 AM
<--before leveler & block
stroker2's Avatar
285's are the same height as your 305's just a little narrower. The 265 is narrower and smaller just fyi
2000 7.3 F-250 4x4 CC/SB Lariat 6-speed, 2.5" leveler and F350 block, Swamps 200/30% injectors, Swamps tunes, GTP-38R, Valair: kevlar/ceramic clutch, 4inch exhaust, AFE stage 2,
DFA-regulated return, pre-pump mods, Isspro boost and pyro, scan gauge, ~420hp and 836tq
stroker2 is offline
post #7 of 31 (permalink) Old 01-05-2011, 01:21 PM
fordfan30's Avatar
You should have no problem getting 1 or 2 more mpg with the 265's. I lost about 4 mpg when I went from 265/70/17 to 375/50/18. There is a ton more unsprung rotating weight.
06 F250 4x4 ecsb, lowered 2", 6 Autometer Phantom 2's, Accufab Elbow, Zoodad, Airaid, Magnaflow 4"dp 5" pipe 7" short stack, Studs, Egr delete, sneaky pipe, regulated fuel return, 6.4 banjo bolts, Moderate FICM, High idle and foglight mods, Bilsteins, Sulastic shackles, DIY Harley headlights and traction bars. 8.76 1/8th
fordfan30 is offline
post #8 of 31 (permalink) Old 01-05-2011, 02:43 PM
tholt34's Avatar
How much difference do you guys think there is in like an AT tire versus like a highway tire?
2000 F-250 ext cab 4x4 6 spd. Glowshift gauges(egt, boost, and fuel pressure), PHP tuned, DIY intake. MBRP 5 inch straight exhaust with 6 inch tip
tholt34 is offline
post #9 of 31 (permalink) Old 01-05-2011, 05:49 PM Thread Starter
Perfect info, it was what I had read elsewhere but more specific to our engines and gear ratios. The height difference (305/70 to 265/75) is very small, like less than an inch overall, but the width is 40 millimeters. I would like to bump up my RPMs for a given speed a bit as well but I don't expect the speedo difference to be much, like 4% or 2 mph at 50 mph.
1 mpg is a big deal for a big truck. It's between a 5 and 10 % improvement.
Easier on brakes, our unit bearing hubs, and the steering system as well.
Kioti CK30 tractor
Highbeam is offline
post #10 of 31 (permalink) Old 01-06-2011, 01:35 AM
MPG Moderator
A green web site did an extensive test on tires and MPG for all size vehicles. At the time the BFG Long Trail 245s gave the lowest rolling resistance for pickup-sized vehicles. Don't know if that's still true or not.
Slammed 4"
Rugged Air Dam
315,000 miles
