2000 7.3 MPG question. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 12-25-2010, 05:04 PM Thread Starter
i got a tony wildman tuner that i run in the low tow settin all the time, w/ an afe stage 1 intake w/ a torque tube, a 4" down pipe to 5" exhaust into an 8" stack. i was curious what ppl w/ similar setups are gettin for fuel milage, also i was wondering if sending my tuner back in and gettin the daily driving settin on it would help out more so then the low tow settin, i'm think it will but i dont know for sure. its gettin avg of about 14 MPG right now which i dont think is bad, i can go roughly 350 miles on 3/4 of a tank of fuel in a 38 gallon fuel tank. any thoughts or help would be apreciated, i'd like to squeeze as many miles to the gallon out of this thing durring daily use as i can, not a huge deal when i'm gettin on it cuz thats usualy the last thing on sombodys mind at that point, lol. thanks guys
sparks427 is offline
post #2 of 11 (permalink) Old 12-25-2010, 05:12 PM
topshelf7.3l's Avatar
Re: 2000 7.3 MPG question.
What size tires you running? I have a Ts chip in my truck I run it on 100 Hp setting. With an afe intake and a 4 inch turbo back. I get 16 average a week if I drive 65mph on the highway ill get 18 or so. But I have 35's on my truck
2005 f250 ex/lb 4x4,egr delete, arp studs, black onyx, 03 turbo,sct xts, 8" procomp, 325/60-20 toyos, 20x10 eagle 068
topshelf7.3l is offline
post #3 of 11 (permalink) Old 12-25-2010, 05:30 PM Thread Starter
ya i forgot to mention that, im runnin 265s right now, but thought about upin to 33s, what would i need to make 35s fit?
post #4 of 11 (permalink) Old 12-26-2010, 02:20 AM
Superstroker123's Avatar
im running a flip chip set at 100hp a Afe Stage one intake, shift kit, four inch exhaust, suncoast torque converter and im getting around 16 around town and 18 hwy and thats with a 8 inch lift and 35x12.50 R18 bfg mudders
2000 F-350 7.3 Powerstroke
AFE Stage One Intake
Four inch Ats Exhaust Duals From Muffler (thinking of straight piping it)
Four Stage Flip Chip (stock,50,100,150hp)
Shift Kit
Mag Tech Tranny Pan
9 Inch Lift
35x12.50r18 BFG Mud Terrains
Moto Metal Wheels
Pioneer Stereo
Two Twelve Inch Subs
Superstroker123 is offline
post #5 of 11 (permalink) Old 12-26-2010, 03:31 AM
Lots to learn
V-Ref's Avatar
Recommend you run the average of 4 tanks, and use a GPS to log your mileage vs. the odo, unless you know it's calibrated spot on. A couple of the garmins I own allow a "track log" that will enable you to see your exact mileage per GPS.
The reason I say 4 tanks, is I can stuff an extra gallon in there depending on how patient I am at the pump...use the same method everytime when filling. That will skew your "mileage" right there...need 4 tanks to "average" that factor out itself.
Probably sounds eye rolling silly, but working off good data, will make sure you spend your money in the right direction towards your goals. A lot may blow this off.....
FWIW-I see right at 13.8 to 14.0 mpg with my truck, winter season, 50% 4wd, 50% highway, 50% city/off road.
If some is good, more must be better.
2000 F250 EC/SB ZF6
Unlimited 400cc/200%
Irate S467 FMW
Stecher Stealth Stage 2
Southbend DD
Irate Fuel System
Swamps HVHF IDM
WOP H11s and Springs
Gearhead/Swamps/Tyrant/Beans tuning
V-Ref is offline
post #6 of 11 (permalink) Old 12-26-2010, 03:44 AM
'01STROKER250's Avatar
is running say a 26575r16 tire worse for you fuel economy than like a 285? this would mean a 265 is too small? i always thought bigger tires made mpgs go down?
2001 F250 7.3l. Off to the shop to become more powerful...
'01STROKER250 is offline
post #7 of 11 (permalink) Old 12-26-2010, 04:35 AM Thread Starter
V-ref, that would make sence, cuz my trucks got 247k on it so theres a good chance it could be off, i did the fuel milage now w/ the weatehr gettin colder and lettin it idle to warm up and it kickin in to high idle, it droped to 12mpgs. i'm not really worried about it since thats not really my main objective but i've seen alot of diesels be able to run good times in the 1/4 and still get good fuel millage, i wasnt sure if the 7.3 was one of them.
post #8 of 11 (permalink) Old 12-26-2010, 06:37 AM
I'm running 285s on a 65hp tune. 70% of my driving is hwy. I get 15-16 mpg. When I had 315s on it, it wasn't all that different, about 14 average..
2000 7.3 F-350, PHP Tunes, 5" straight pipe, intake, gauges
forddieselkicksass is offline
post #9 of 11 (permalink) Old 12-26-2010, 08:01 PM
MPG Moderator
Dave Whitmer's Avatar
No way 285s get anything but WORSE MPG than 265s.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #10 of 11 (permalink) Old 12-27-2010, 02:17 AM
bulletproof7.3's Avatar
Been gettin right around 16-17 running tonys tunes on daily when i calculate it by mileage and how many gallons at the pump. Sittin on 37s i think thats really good
2000 f250 , 7.3 built trans, K&N intake, warn lock outs, Tonywildman , 4" down pipe to 5" silverline exhaust, ported compressor housing, 07 hd headlights,trans temp, boost, and egt gauges .
bulletproof7.3 is offline
