2000 F250 CC/Sb fuel mileage - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-29-2010, 01:38 PM Thread Starter
StrokeIt2000
mstadler13's Avatar
I have a 2000 Ford F250 and I am just wanting to see what type of mileage I should be getting out of my truck between fill ups. I think mines a little low. I have stock 3.73 gears, 35x12.5x18's, 6.5" pro comp lift, DIY Tymar, Edge CS programmer set on Extreme (100hp), 4" turbo back with no muffler. I am getting 315 miles per fill up and thats putting in between 24.5 and 25 gallons.
mstadler13 is offline
post #2 of 11 (permalink) Old 10-29-2010, 01:41 PM
Crazy wid da cheeze wiz
David N's Avatar
Re: 2000 F250 CC/Sb fuel mileage
I would think you would get better than that, but it all depends on driving habits. How many miles are on your truck? You could have a weak HPOP.
I get about 16 mpg out of my truck, of course I only have 285's, and different tuning too.
2002 F-250 CCSB Lariat 4x4 7.3 Mostly stock... for now
2003 Ford Ranger Fx4 Level ll Sonic Blue with 33s"
Originally Posted by Steamfighter View Post
I'm getting it in the can right now!!
David N is offline
post #3 of 11 (permalink) Old 10-29-2010, 01:43 PM Thread Starter
StrokeIt2000
mstadler13's Avatar
I have just over 200k on the truck and I baby the truck for the most part. But I don't put on highway miles either. It's mainly around town and in the country 55mph
post #4 of 11 (permalink) Old 10-29-2010, 02:40 PM
<--before leveler & block
stroker2's Avatar
I have the same truck but i have a zf6 and 285's with an 2.5in lift and i got 19.3mpg half town and half highway last fill up with my mods in sig.
2000 7.3 F-250 4x4 CC/SB Lariat 6-speed, 2.5" leveler and F350 block, Swamps 200/30% injectors, Swamps tunes, GTP-38R, Valair: kevlar/ceramic clutch, 4inch exhaust, AFE stage 2,
DFA-regulated return, pre-pump mods, Isspro boost and pyro, scan gauge, ~420hp and 836tq
stroker2 is offline
post #5 of 11 (permalink) Old 10-29-2010, 02:43 PM Thread Starter
StrokeIt2000
mstadler13's Avatar
Thats awesome. I am currently in the market for some new injectors and customs tunes from PHP on my Edge CS. Hopefully that will make a big difference. Just want to make sure that I don't have any problems I need to take care of first.
post #6 of 11 (permalink) Old 10-29-2010, 02:47 PM
stroker2's Avatar
I let my truck warm up for a little over 5 minutes in the morning before i drive it also. Do you let it set and idle much? And what kind of driving do you do? Mostly highway? Mostly town? 50/50?
stroker2 is offline
post #7 of 11 (permalink) Old 10-29-2010, 03:04 PM Thread Starter
StrokeIt2000
mstadler13's Avatar
I let it sit and idle for a couple minutes before I take off. When it comes to driving it's mostly town and country driving. 60mph and less. Rairly does it see the highway.
post #8 of 11 (permalink) Old 10-29-2010, 07:11 PM
David N's Avatar
The injectors, turbo, a better HPOP, and good tuning will give you an increase in MPGs. As long as you keep your foot out of the go-fast pedal most of the time.
David N is offline
post #9 of 11 (permalink) Old 10-29-2010, 10:35 PM
MPG Moderator
Dave Whitmer's Avatar
12-13 MPG for a lifted CC with 315s, 4x4, automatic, driven mostly in town - - sounds about par for the course.
Don't let her idle more than a few seconds. With HEUI, if the engine is running, you have oil pressure. These engines are so efficient it will take all day to warm them up unless you put a light load on them. In-town driving will warm them up in a couple miles.
I've tried injectors - no joy. I cannot see how HPOP will improve MPG.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #10 of 11 (permalink) Old 11-03-2010, 01:14 AM
peterbilt'in
Rob02F350's Avatar
kinda seems like the lift is hurting.
Saturday morning to Sunday night, i drove 182 miles. horrible up and down hills 30-55mph. and a few blasts on the highway @ 70-75.
top'd off sunday night with 10.1 gallons.... so call it 18 even? in the "80E" tune.
2002 F350 extended cab XLT, 4x4 auto,194K mi @ 10/25/13, ELF7405, DP F5, ultra light gauges, all kinds of "improvements" Yukon Grizzly locker 6K helper springs, x code fronts. 2 Y2K jetta Tdi. RC2 tuned
Rob02F350 is offline
