More MPH = More MPG? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-23-2008, 06:48 PM Thread Starter
OBS junkie
Cat_Rebel's Avatar
I think you'll enjoy this one Dave. This guy must have been drunk or his speedO was WAAAAAAAAAAAAY off.
http://www.thedieselstop.com/forums/...46/index2.html
i have noticed with my truck, the faster i go on the highway, the better mileage i get. for example at 65 i get roughly 17-18. if i bump it to 70 its gets 19-20. but then another jump at 80 to about 21. one long drive thru west texas got me 23-24 going 85-90. around town it is about 15 or 16 depending on how easy i drive it.
His truck in sig
94 7.3 IDI non-turbo XL 350 super cab long bed
autojet y pipe and a used p-stroke exhaust on the end of it 235xxx miles, amsoil full bypass system, coolant filter
This might be the true problem right here though...(quoted right from his own sig)
probally the youngest member of the tds
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #2 of 6 (permalink) Old 02-23-2008, 07:23 PM
Starting Over
kainers's Avatar
Re: More MPH = More MPG?
My Fil get 20 in his.I found a 86 auto 4X4 6.9 for 1k in the paper yesterday I might scoop it up.
kainers is offline
post #3 of 6 (permalink) Old 02-23-2008, 07:47 PM
Bugman's Avatar
It has been a long time since I was in west Texas and not to offend any Texans since that was my second home while I was growing up, but doesn't the wind always blow through that section of Texas? If it does he just might of gotten a great tail wind to where he could of shut off the engine riged a sale and off he would go.
Jim
Bugman is offline
post #4 of 6 (permalink) Old 02-24-2008, 02:11 PM
PSN Mega Miler
crowz's Avatar
Must be an advantage the earlier trucks had over mine because up to 60mph is my best mpg and after that it goes down fasssst
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #5 of 6 (permalink) Old 02-25-2008, 06:06 AM
I guess there is technically a way that MORE MPH=MORE MPG... And the only way is if you are driving around at lower speed lower gear... Optimallly you want to be on your highers gear for best fuel economy... so probably if you do 50 and you are in 5th gear (and don't want to shift... ) you get worse than 55 in 6th (for some strange reason you only shift at 52.69876 MPH....
99.5 F250 2wd 6Speed: DP Tuner, Straight Pipe, DIY Tymar, 203 Thermostat. Spec Focus Hauler!!
23.5 MPG (HIGHWAY)
17.5 MPG (City)
INFOCUSHAULER is offline
post #6 of 6 (permalink) Old 02-25-2008, 07:07 PM
Tampa450's Avatar
My 250 will shift into OD at around 45mph.
Best possible fuel mileage would be at 45-50, after that it geos down...period.
-Shawn Collister #16
-2002 F250 Crew/4x4/Auto- 4" Magnaflow, AIS, Vegistroke, ScanGauge, AC's tuned by Swamps
-2003 F450 Crew/4x4/Auto- 4" exhaust, Alcoas, Air ride, AIS, Garrett 38R, X-monitor
Tampa450 is offline
