Fuel Econ - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 08-01-2010, 06:43 PM Thread Starter
Zrock's Avatar
Fuel Econ
Just started to run my First tank of Husky/Mowhak Premium Diesel. Even before i have droped 1/4 tank i have already noticed a significant increase in fuel econ. Decided i would switch over and give it a test for a few tanks. Acording to their website you are suppost to see a 2-5% increase in fuel econ. Also says no need to run a additive as it is not suppost to be as dry as ulsd. guess ill see at the end of this tank how much it actually has increased. Its not any more expencive as any other diesel
Zrock is offline
post #2 of 9 (permalink) Old 08-01-2010, 10:59 PM
MPG Moderator
Dave Whitmer's Avatar
Re: Fuel Econ
More snake oil.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #3 of 9 (permalink) Old 08-01-2010, 11:51 PM
Science rulz
Coltaine's Avatar
Send a message via AIM to Coltaine
Re: Fuel Econ
Originally Posted by Dave Whitmer View Post
More snake oil.
I run farther on Shell's "Ultra Diesel" then I do on what I buy from the local fuel pusher's stuff. But the local fuel pusher's low price evens it out in the end.
One of them truckless bastards.
Coltaine is offline
post #4 of 9 (permalink) Old 08-04-2010, 05:09 PM Thread Starter
Zrock's Avatar
Re: Fuel Econ
Still seem to be getting way more fuel econ... Even after a night of balls to the floor to get the GF to hospital after her watter broke
Zrock is offline
post #5 of 9 (permalink) Old 08-05-2010, 06:02 PM
Re: Fuel Econ
Ewh, I always threatened to make the wife ride in the bed of the truck or sit on a blue tarp to prevent that "water" from getting in the cab. Usually you don't get back out to the truck for a day or two and buy then that "water" may do some bad things to your truck.
No longer an issue.
2000 F350 SRW, 4wd, CCSB, PSD
Lowered rear end to F250 height, 4" exhaust w/ muff, foil delete, AIH delete, Ford AIS intake, tru-cool trans cooler, autometer under dash pod and gauges, Mile Marker hubs, 04 headlights, soft tonneau
18' 10k rated PJ car hauler
26' 7500# Creekside RV Trailer
Kioti CK30 tractor
Highbeam is offline
post #6 of 9 (permalink) Old 08-06-2010, 04:37 PM Thread Starter
Zrock's Avatar
Re: Fuel Econ
ahhh wasent to bad i was able to take a towel and soak it all up later that night... No ill after effects..hehe
Zrock is offline
post #7 of 9 (permalink) Old 08-15-2010, 03:48 PM Thread Starter
Zrock's Avatar
Re: Fuel Econ
Well for a so called snake oil im liking the bennifits im seeing... So far i have gained a few points in fuel millage, truck is running smother and actually seems to accelerate better...
Zrock is offline
post #8 of 9 (permalink) Old 08-20-2010, 09:02 PM
secondarychaos's Avatar
Re: Fuel Econ
Dave, don't you think diesel with a little higher cetane rating would burn a little more efficiently?
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #9 of 9 (permalink) Old 08-20-2010, 11:32 PM
MPG Moderator
Re: Fuel Econ
Higher cetane makes a diesel easier to start in any weather.
Higher cetane allows you to run higher RPM because it burns faster.
Higher cetane would make you run less advance. In fact,it is like propane in that too much advance with high cetane would bend rods.
I don't see any way higher cetane improves MPG.
What I'd want to see from a high-MPG fuel is:
Higher heating value
Lower viscosity so it could be run through smaller nozzles.
Slammed 4"
Rugged Air Dam
315,000 miles
