Splits vs. Singles - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 07-18-2007, 02:39 PM Thread Starter
Harry Callahan
Splits vs. Singles
For anybody that has actually swapped out splits for some comparable size singles - What kind of changes did you notice, especially on the noise?
RDRCM#10
A select band of brothers- We stand together as one.
Giant VT-3, not stock
sniperonhigh is offline
post #2 of 21 (permalink) Old 07-18-2007, 03:16 PM
Laces Out
bigrpowr's Avatar
Re: Splits vs. Singles
good question..im curious too.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #3 of 21 (permalink) Old 07-18-2007, 05:09 PM
gregrob's Avatar
Well, noise definitely went up but I kinda like the sound better. Sounds more "healthy" to me.
Mileage, in town and towing is definitely up, I think the Terminator helps with that as well. In town I barely have to touch the throttle.
Freeway mpg, I honestly haven't had the chance to do a *good* test.
Example: I got 18.5 on the splits crusing at about 72mph mixed with some in town (denver) driving.
I have ran interstate with the singles, but never a whole tank that slow, usually 75-80 at least.
I do know it got 15.5 pulling a 20' gooseneck (empty), and it maybe would have done 12 before. I possibly attribute that to the 2 stroke oil I'm running as well.
gregrob is offline
post #4 of 21 (permalink) Old 07-18-2007, 11:12 PM
I'm thinking about getting some singles. But nothing to hot I do allot of towing and worried about egt's maybe something in the 40hp range or so. I like the idea of better fuel mileage also. Any suggestions?
00 Powerstroke, Garrett BB, Dp-tuner in the glove box, F-5 in the mail, Afe Stage 2, HPX SS Crossover, ITP Diesel CCV Mod, BPV delete, AIH Delete, flux capacitor with hyper drive, ITP 7.3L Regulated Return Kit, fuel system, magnaflow 4" Turbo Back exhaust w/5" tip.
KOZ
TurboDiezel is offline
post #5 of 21 (permalink) Old 07-18-2007, 11:37 PM
gregrob's Avatar
If you're keeping a stock HPOP I would go with some 160cc stage 1 singles, or AC codes. (same thing AC's are just factory Int'l, 'Stage 1s' are reworked AA's from an aftermarket shop)
If you plan on twin HPOPs in the future you can go a little more fuel, like 180-195cc and if you keep a stock nozzle it's not too hot on a good tow burn.
gregrob is offline
post #6 of 21 (permalink) Old 07-19-2007, 02:11 AM
Ive noticed with the larger turbo my mileage dropped considerably. I was averaging 17+- with AB's and stock turbo, now its anywhere between 13-14 mpg. My big b codes also average 13-14 with the big turbo.
2013 ccsb 4x4-stock
99 ccsb 4x4- built to the hilt, wife's DD!
Short Bus is offline
post #7 of 21 (permalink) Old 07-23-2007, 06:47 PM
Sponsor
VanAackenBrosRacing's Avatar
Send a message via AIM to VanAackenBrosRacing
well, swapped stage 1 singles for a temporary use of stage 2 splits. fuel mileage went way down and power went down as well. this is all with the use of a terminator. Cant wait for the singles to get back!
EMPIRE DIESEL PERFORMANCE OF DUBUQUE IA
Procharger kits for 6.0 and 7.3 powerstroke and LBZ/LMM NOW TAKING ORDERS!
Procharger Cummins kit in R&D
Billet Camshafts w/Custom Firing Order for Duramax Smooths dmax harmonics to prevent #2 journal crankshaft failures in high HP builds.
Precision Turbos Custom 2.6, 2.8, 3.0 billet chargers
VanAackenBrosRacing is offline
post #8 of 21 (permalink) Old 07-23-2007, 11:53 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I would say about the same for mine... switched from AD's to stage 2's... didnt knotice any change in fuel stops...
Joe
CSIPSD is offline
post #9 of 21 (permalink) Old 07-25-2007, 03:15 AM
Starting Over
kainers's Avatar
singles are noisy and no change in fuel economy.
kainers is offline
post #10 of 21 (permalink) Old 07-26-2007, 03:19 AM
Non Helpful Member
Deerezilla's Avatar
What kind of MPG are you getting with the hypermax stage 2 injectors?
2 fords that make no power
Deerezilla is offline
