Check Yo' Brakes! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 08-07-2007, 10:44 PM Thread Starter
MPG Moderator
Dave Whitmer's Avatar
Check Yo' Brakes!
I heard this elswhere but dismissed it as urban legend, but then time came for new brakes and Shazam! 2 MPG! My brakes were dragging.
Apparently these sintered metallic brakes we use corrode on the ends and swell as they do so. Once they swell beyond the normal clearance, they drag. MPG and other performace is degraded. And the brakes get hot.
A little file work will bring the pad ends back where they belong, I am told.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #2 of 21 (permalink) Old 08-08-2007, 05:27 PM
TRX370r's Avatar
Re: Check Yo' Brakes!
did you do just a pad change? If so which ones?
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.
Thomas Jefferson
Beans Diesel Performance
TRX370r is offline
post #3 of 21 (permalink) Old 08-08-2007, 11:33 PM Thread Starter
MPG Moderator
I was doing the pad change anyway. My OEM pads were shot.
Under normal circumstances a little grinder work obviates the need to change pads.
Slammed 4"
Rugged Air Dam
315,000 miles
post #4 of 21 (permalink) Old 08-09-2007, 03:20 PM
TRX370r's Avatar
My oem's are shot as well. Rotor's still look good, what is the best pads you have found for oem rotors?
Thomas Jefferson
TRX370r is offline
post #5 of 21 (permalink) Old 08-09-2007, 10:21 PM Thread Starter
MPG Moderator
I didnít use OEM rotors. Mine were shot.
I used the Performance Friction pads and rotors.
Slammed 4"
Rugged Air Dam
315,000 miles
post #6 of 21 (permalink) Old 08-10-2007, 01:18 AM
Edward Scissorhand WanaB
Bushwakd's Avatar
How do you like the PF rotors and pads?
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #7 of 21 (permalink) Old 08-10-2007, 01:45 AM Thread Starter
MPG Moderator
Very smooth. They don't squeal in humid weather. Haven't really challenged them though.
Slammed 4"
Rugged Air Dam
315,000 miles
post #8 of 21 (permalink) Old 08-10-2007, 02:33 PM
West Bound and Down
scarlet_nape's Avatar
I just put on some Hawk pads and am very happy with them. Rotors were fine, so I just had them turned.
Life is tough.....it's even tougher if you're stupid. -John Wayne
#53
scarlet_nape is offline
post #9 of 21 (permalink) Old 08-10-2007, 11:09 PM Thread Starter
MPG Moderator
What I'm alerting everyone to is that otherwise A-OK brakes might be dragging on the edges. I don't give a rip what brand of brake pads you use.
Jack up you front wheels and give them a spin. They should spin freely. If they drag to a stop in less than five revolutions, pull the pads and file off the swelled edges some.
It is worth 2 MPG and will make your pads and rotors last longer.
Slammed 4"
Rugged Air Dam
315,000 miles
post #10 of 21 (permalink) Old 08-11-2007, 04:31 PM
gregrob's Avatar
Thanks for the info Dave. I'm gonna check.
gregrob is offline
