my mpg experiment - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 05-17-2010, 05:15 AM Thread Starter
my mpg experiment
So about a month or so ago I bought a 2000 Excursion with a 7.3. I drove it a couple weeks to get a feel for it. I averaged 16.4 mpg on a trip I take often. I added Airaid intake, 4 inch turbo back exhaust with a shorty Aero muffler and a set of factory 20s with 275/65-20 stock tires. I took the same trip this weekend and averaged 19.9 mpg. I didnt use the cruise, and did some hypermiling techniques. Im hoping with a little more practice I can get 22 out of it.....
If I add a ZF6 tranny to it, what kind of gains you think I could see...
Heartbeatracing is offline
post #2 of 8 (permalink) Old 05-17-2010, 05:16 PM
secondarychaos's Avatar
Re: my mpg experiment
Zf6 will mostly give you gains by allowing you to drive it more efficiently, so it could vary greatly how well you'll do.
Are those figures hand calculated?
Dan
96 Powerstroke: 6637, downpipe to dump exhaust, 140v IDM and a shift kit.
84 Honda Sabre V65 1100: pipes, jet kit and new tires. Faster than I think I'll ever need.
secondarychaos is offline
post #3 of 8 (permalink) Old 05-17-2010, 07:52 PM
MPG Moderator
Dave Whitmer's Avatar
My guess is you'll pick up 2-3 MPG plus the fact that coasting is a lot more effective with a stick.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
post #4 of 8 (permalink) Old 05-18-2010, 01:40 AM Thread Starter
yes hand calculated. I want to do the 6 speed swap, I have access to everything needed... just hate to cut a hole in the floor of my EX
post #5 of 8 (permalink) Old 05-18-2010, 03:02 AM
MPG Moderator
You can always patch a hole. Its just sheetmetal.
Slammed 4"
Rugged Air Dam
315,000 miles
post #6 of 8 (permalink) Old 05-18-2010, 03:04 AM
yup. do it. lots of info in the trans section and the engine/trans swap section.
Dan
post #7 of 8 (permalink) Old 05-18-2010, 12:12 PM
TARM's Avatar
Big Stroker just finished a convert on his SD send hima PM as he took some good pictures and what not.
The X can get some decent MPG on highway cruising and overall. I find it funny it has such a bad rap for mph but that os from the gassers with thre singel digit city numbers when run hard. The diesels getsbetter mpg than most all of the small based foriegn pickups and most all SUVs from that time an many today.
If you have not take the cross beams off the roof rack. They are not useable wear the paint off the roof and likely don't do much for wind resistance. For coasting I would think you could wire up a converter lock unlock switch you can get a lot more out of coasting or shifting to N not always a good idea but effective. I live in the mountains and on certain grades they are perfect for it as other traffic is almost nonexistant. Can go over 4 miles without touching the go pedal.
I get about 18 combined driving and 21 highway 17 all city. [email protected] tunes added about 1.5-2 mpg to my mpg. Also it needs to be realized my highway or city driving is not like that of Tx Fl as it is quite hilly with very little if any completely flat areas. Becasue of this I found driving 68-69 actually gives me better mpg as I am in a better part of the curve for the hills. But when I get near DC and head down 95 south best mpg is 55-60 I usually run 65. There I am thinking I can get closer to 23 but have not run it since the chip. Would love to run on some really flat areas like alot of I 10 from Ga -Tx or FL highways.
All my mileage is calculated by hand . Fill up goto clear fuel up to edge of the mouth. Takes a bit to constantly wait on the foam to back down.
TARM is offline
post #8 of 8 (permalink) Old 05-18-2010, 12:53 PM
Jack Ken
We used to get right at the 19-20 mpg on the highway in our 03 ex. but lately ibe been averageing 13-14 used to average 16-17. I just changed the oil and that didnt help, Ive got an ICP sensor to put in now to see if that helps ( it was seaping anyway).
2003 Exursion 7.3 diesel exhaust, intake, ts chip, banks exhaust housing, big head actuator all sittin on 20s w/ 35s.
1989 F350 460 propane, 4inch lift 39.5s
1988 bronco ii 2.3 turbo motor on propane
fordman2121 is offline
