10mpg is it possible? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 30 (permalink) Old 01-20-2008, 09:52 AM Thread Starter
urbanwheeler's Avatar
since doing my last mods i have dropped to 10 mpg. i was getting 12 around town and 12.7 on the freeway on cruise control, flat ground. at 65mph, cruise on, flat ground, 2250rpm i am making 11psi. could the 11psi be killing my mileage? i am running 35's and 4.10's. i will be dropping to 3.73's and up to 37's. hopefully this will drop my rpm's and help mileage. what do you guys think?
'96 f-250, auto, shackle flip, solid axle, rsk, high/crossover steering, 3.73's, true trac's front and rear, trac bars, gt4202, 7.3 ic, idm mod, ccv mod, A1000, 4-line DIY Gen3, dual ipr's, casserly 350/200's, arp studs, 910's, pushrods, elec. fan, 2-stage nitrous, fluidampr.
[SIGPIC][/SIGPIC]
urbanwheeler is offline
post #2 of 30 (permalink) Old 01-20-2008, 09:56 AM
<----Simply the best.
StrokerTurbo7.3's Avatar
Send a message via AIM to StrokerTurbo7.3
Re: 10mpg is it possible?
That lift isnt helping I'm sure. Taking it easy most of the time I get about 15 mpg or so. It varies because its hard to take it easy. Although my truck doesnt have quite as much as yours. These winter months though I cant calculate what I am getting because it would be so off from letting it sit and warm up.
No longer a proud member of PSN.
StrokerTurbo7.3 is offline
post #3 of 30 (permalink) Old 01-20-2008, 06:32 PM
The Oracle
BigRed97's Avatar
Send a message via AIM to BigRed97
holy bad mileage....something is WAY WRONG
i get 19-21 mpg (city and highway but mostly city)
and thats with 4.10s and 38s
CCLB with some stuff done .....
BigRed97 is offline
post #4 of 30 (permalink) Old 01-20-2008, 06:35 PM
OBS junkie
Cat_Rebel's Avatar
Yep it's possible, winter is really hard on Diesels. Drive it easy & try to keep the RPMs below 2000 & see if that helps.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #5 of 30 (permalink) Old 01-20-2008, 06:45 PM
It's the lift and tires. Not saying it couldn't be better, but I get 14 in truck with stock suspension / tire size. I'm sure if I added a large lift and tires with the way I drive, it would drop to 10-12.
The reason for the drop after the mods is your right foot.
gregrob is offline
post #6 of 30 (permalink) Old 01-20-2008, 06:49 PM
The Oracle
BigRed97's Avatar
i tend to disagree with the tires beign the reason....my mileage didnt change with
my lift/tires
BigRed97 is offline
post #7 of 30 (permalink) Old 01-20-2008, 07:00 PM
OBS junkie
Cat_Rebel's Avatar
I'd have to disagree too Greg, if you have the right gear/tire/driver combo you can still get decent MPG with a lifted truck.
RIP Will Iott
post #8 of 30 (permalink) Old 01-20-2008, 07:02 PM
That would be a first. You honestly think jacking it up 8" and adding a huge amount of rolling resistance didn't decrease the mileage?
Did you have your speedo corrected?
BTW, I'm gonna redirect this to the mpg forum. Maybe Dave will chime in for us.
gregrob is offline
post #9 of 30 (permalink) Old 01-20-2008, 07:02 PM
You're putting words in my mouth
I never said you "couldn't get decent mileage" I said it would cause a decrease on the same truck before / after.
At least that's what I meant
gregrob is offline
post #10 of 30 (permalink) Old 01-20-2008, 07:07 PM
The Oracle
BigRed97's Avatar
i do understand where your coming from, im just speaking from my personal experiences....
my speedo is corrected also....before lift/tires milage was 19-21, after lift tires and corrected speedo my mileage was still 19-21...
but its all in the way you drive, i dont go tearing arse all over the place...the truck hardly ever sees over 2200rpm and thats only at a shift usually cruise around at 1100-1600 rpm
BigRed97 is offline
