Normal 6.0 MPG? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 01-26-2018, 11:35 PM Thread Starter
Kut_Throat's Avatar
Normal 6.0 MPG?
I have a 2004 6.0 CCSB with a 4” lift on 315/75r16s and hand calculated I am looking at 13-13.5 all year long. No matter if it’s highway or city, summer or winter fuel. The truck is bulletproofed and has just about every popular 6.0 mod. Straight pipe exhaust and all that. Is this what everyone else is seeing or should I start looking for a problem?
Kut_Throat is offline
post #2 of 4 (permalink) Old 01-30-2018, 01:11 PM
Weatherlite's Avatar
Garage
Re: Normal 6.0 MPG?
With tires like that a a lift, you're probably in the right ballpark. Sadly, you're getting better mileage than I am currently. Not sure what it is, but my rig HATES winter fuel. I'm lucky if I get 13 in the winter. lol However, I WAS getting 16 in the summer as an average. Then, I installed a PHP FICM tune and mileage bumped by about 2 MPG...3 in some cases. So, that may be route you'll want to look into. I would also make sure you've got decent fuel pressure. From what I understand, lower pressures create larger droplets which don't burn as easily. Probably miniscule, but something to consider. Other than that, I've found my biggest improvement came from my right foot, the FICM tune, and making sure everything was running smoothly.
2004 Excursion 6.0
New HPOP/HPO system o-rings; Updated standpipes and dummy plugs
EGR delete; Rebuilt oil cooler; CCV collection mod
VR Black Diamond head gaskets and ARP studs
Oil and coolant bypass filters; Shell EC-1 coolant
Rebuilt turbo; 250 amp alt; 6000 watts of brain scrambling
One giant 240 pound English Mastiff riding shotgun!
Weatherlite is offline
post #3 of 4 (permalink) Old 01-30-2018, 10:45 PM
Re: Normal 6.0 MPG?
Amen to what Weatherlite said. I’m running 320/20s with a 3” leveling kit on my 07 king ranch.
Ficm with Atlas40 gets me high 13s around town and 18+ highway babying it (75 mph max)
bluedorito60 is offline
post #4 of 4 (permalink) Old 02-20-2018, 06:42 PM
MPG Moderator
Dave Whitmer's Avatar
Re: Normal 6.0 MPG?
You are getting what your rig should expect.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
