1999 F350 11 mpg - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 11-21-2017, 02:54 AM Thread Starter
Garage
1999 F350 11 mpg
Complete details and mods
1999 F350 4x4 ex cab long bed Auto 7.3
Trans fresh upgraded rebuild by local builder, upgraded TC
PHP Hydra with swamps tunes
non-ebpv pedastal
wicked wheel equivalent
rebuilt stock turbo
NAPA 6637 filter
SRW Fiberglass service body with ladder rack
T500 HPOP
tank mods
Low rolling resistance tires 265/75/16
3.73 gears
With a full tank of fuel and tools truck weighs in at 9200, gvw9900
Brakes completely redone, new calipers,rotors everything
With a daily driver tune the best I have gotten is 13mpg. That was babying it and trying to see what I could get. Recently tried again and it only got a little over 11mpg.
If I run a more aggressive tune I get 9-11 mpg
1999 F350 Ext cab LB UFiberglass utility body SRW 4x4 auto
Magnaflow 4" turbo back
08 style tow mirrors
jesse24spd is offline
post #2 of 21 (permalink) Old 11-21-2017, 03:08 AM
Project Shamu
Lt.Dan's Avatar
Re: 1999 F350 11 mpg
I have damn near the same mods as you except i have 4.11s and 33s and my truck weighs in at around 6500#. A 50/50 mix of freeway/city I'll get 16.5mpg at best. All city it drops to 15mpg, and if I'm hard on it, about 11mpg. But 2700 lbs is a big difference, weight plays a HUGE difference in mileage. I'm also 2wd, so your pushing around a lot more rotating parts.
Not saying 11mpg is normal, but its not far off from a lot of guys on here.
Have you checked EBPV Tube and sensor?
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #3 of 21 (permalink) Old 11-21-2017, 04:42 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Start with checking the fuel filter in the valley. Simple stuff first.
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #4 of 21 (permalink) Old 11-21-2017, 09:55 AM
alleged moderator
tjctransport's Avatar
doe sit do any idling? city driving? low speed driving? traffic driving? drive like granny going to church on sunday, or like a teenager racing on saturday night?
all that will effect mileage.
tom
tjctransport is offline
post #5 of 21 (permalink) Old 11-21-2017, 12:12 PM
transfixer's Avatar
I've got basically the same setup as you do, truck loaded with toolbox and normal carry stuff weighs around 9,000lbs. I can get 13-13.8 in normal city driving,
Early 99 F350 Crew Cab long bed,
Edge tuner running on tow mode
Stock injectors
Cold air intake
Muffler delete
Cat delete
Stock size exhaust, just a straight pipe now though.
265/75/16 Toyo AT tires
3.73 gears
transfixer is offline
post #6 of 21 (permalink) Old 11-21-2017, 12:48 PM
cpdad93's Avatar
I imagine the wind drag on that plow and light bar must be worth 1-2 mpg.
cpdad93 is offline
post #7 of 21 (permalink) Old 11-21-2017, 02:15 PM Thread Starter
Garage
Fuel filter and oil change completed recently.
I've tried driving like miss daisy, highway, city, mixed use doesn't matter how I drive mileage is always about the same.
The ebpv tube has been deleted and the sensor is to atmosphere.
The most I ever saw from the truck was 15.7, when I first started driving it back in may.
Hardly ever sits and idles.
I know its not going to get 20+mpg, but a consistent 13 or 14 would be nice. Especially knowing that guys towing 13k get better mileage than I do on occasion.
post #8 of 21 (permalink) Old 11-22-2017, 02:41 AM
Project Shamu
Lt.Dan's Avatar
The ebpv tube should not be deleted. It has been said that the EBPV sensor is used to modify the fuel tables. So if it sees atmospheric pressure all the time, it might not be adjusting when it needs to, or be adjusting when it doesn't need to.
I would get that hooked back up.
SOLD
Lt.Dan is offline
post #9 of 21 (permalink) Old 11-23-2017, 12:02 PM
410customs's Avatar
Make sure you are talking about the Exhaust back pressure sensor and tube (mounted in front of the Hpop) not the exhaust back pressure actuator which is commonly deleted from the turbo pedestal
I know people get these two confused
2001 Excursion 7.3, auto, 4x4, 3.73, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
21.9 liter family
410customs is offline
post #10 of 21 (permalink) Old 01-02-2018, 12:04 AM
I've got a 1999 F-350 that was getting 18-20 mpg than started dropping down to 11.5 replaced all injectors (NEW not rebuilt) still @ 11.5 anyone got some answers, What is this ebp delete a couple of guys have mentioned, isn't that sensor needed ?
Cloudwalker is offline
