Fuel Additives - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 01-09-2008, 09:48 AM Thread Starter
Fuel Additives
Do you run additives or staight diesel? When I bought my truck I was warned about running the new ULSD as it would kill my fuel system because there isn't enough lube in it. I was using FlashLube at first but when I went to Cali I couldn't find it so I started using Diesel Kleen is what I think it was called. I don't get as good of mileage with Diesel Kleen. So I was wondering what everyone else uses.
SquirrelCrusher is offline
post #2 of 9 (permalink) Old 01-09-2008, 03:52 PM
matthewd11's Avatar
Re: Fuel Additives
I use Howe's, i just switched from diesel kleen
matthewd11 is offline
post #3 of 9 (permalink) Old 01-09-2008, 04:07 PM
<----Colin Banks
mattymx's Avatar
Re: Fuel Additives
Here is what you need to do. Look at the picture below and look up the item you are using. The idea here is to use a product with an HFRR rating of 520 or lower. The higher the number, the less it lubricates. Both Howes and diesel kleen fail to add lubrication to the fuel. I use super tech 2 stroke oil have have seen great results along with a lot of others.
mattymx is offline
post #4 of 9 (permalink) Old 01-09-2008, 04:19 PM
Re: Fuel Additives
https://www.powerstrokenation.com/for...read.php?t=310
or if you want a much simpler approach read that lol
PMRCM#1
slowleak is offline
post #5 of 9 (permalink) Old 01-09-2008, 11:56 PM Thread Starter
Re: Fuel Additives
I read the thread on the 2 stroke oil and I am going to have to give that a try when I get back to my truck. I am on vacation right now
post #6 of 9 (permalink) Old 01-11-2008, 07:31 AM
GPD270's Avatar
Re: Fuel Additives
I read the whole thread but still could not figure out if it was ok to run in 6.0's.... the 2 stroke oil.
GPD270 is offline
post #7 of 9 (permalink) Old 01-11-2008, 07:36 AM
Re: Fuel Additives
i dont see why not
PMRCM#1
slowleak is offline
post #8 of 9 (permalink) Old 01-17-2008, 04:49 PM
Re: Fuel Additives
I've used Stanadyne in the past but blend in biodiesel these days.
hheynow is offline
post #9 of 9 (permalink) Old 01-23-2008, 12:53 PM
Freedom is not free
White Buffalo's Avatar
Re: Fuel Additives
Here is the link to the full report of the chart that Mattymx posted.
http://www.johnfjensen.com/Diesel_fu...itive_test.pdf
FWIW, I use Schaeffer's dieseltreat - with the added lubricity most that use it have seen a 1-2 mpg increase.
Beware if using the 2 cycle oil on 2007+ newer engines running a DPF. It icreases the sulfur content and could clog the DPF early.
White Buffalo is offline
