1999 F450 MPG improvements - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 18 (permalink) Old 01-13-2017, 06:14 PM Thread Starter
brandon_oma#692's Avatar
Garage
Hi everybody,
I love my truck. it has been my project for the past year and will continue to be. Up until about a month ago I only drove it when I needed a truck. now it is my daily driver. It is a late 1999 F450 2wd 7.3 with the zf6 and 4.88 gears. Driving back and forth to work I try to keep between 50 and 55. 55 is 2100 rpm per the scangaue 2 or 2000 per the dash tach.
This spring I'm putting a locker and am thinking 4.10 gears at the same time. I may or may not switch. It pulls the camper and the gooseneck very well as it is.
Wonder about aerodynamic gains. I know the flatbed is not helping. wondering how much improvements I should see with a front air dam and any suggestions to the design of it. I know Dave has made a few. Sorry I do not want to ditch the big mirrors. just too handy.
Also wonder about adding skirting to the bed. I would like to add some toolboxes anyways.
Any thoughts
Edit I added a picture of the truck not sure if it is working properly
brandon_oma#692 is offline
post #2 of 18 (permalink) Old 01-13-2017, 07:03 PM
79jasper's Avatar
Re: 1999 F450 MPG improvements
What mileage are you seeing?
You may be getting all you can get already.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #3 of 18 (permalink) Old 01-13-2017, 07:50 PM Thread Starter
Garage
I'm around 13 to 14 average I think. I just fixed the filler neck last week. I was getting inconsistent fills so it was hard to tell. I had this same engine in my 250 and got 15-16 but that truck was lighter and 3.73 gears but less mpg friendly driving habits.
post #4 of 18 (permalink) Old 01-13-2017, 09:03 PM
79jasper's Avatar
For a 450, that's probably about the best you can get.
Gears will help, but it will take a very long time to see a breakeven point.
79jasper is offline
post #5 of 18 (permalink) Old 01-13-2017, 09:30 PM Thread Starter
Garage
Yes I agree. the only reason I am considering it as I will have the carrier out to replace with a locker.
post #6 of 18 (permalink) Old 01-13-2017, 11:25 PM
79jasper's Avatar
Well that would be a good time to do it.
Going off memory, but I don't know if lower gears are available for the 10.5 (which is I think what you have)
79jasper is offline
post #7 of 18 (permalink) Old 01-14-2017, 12:03 AM Thread Starter
Garage
Dana 80
post #8 of 18 (permalink) Old 01-14-2017, 12:04 AM Thread Starter
Garage
It is a big sob
post #9 of 18 (permalink) Old 01-14-2017, 01:07 AM
79jasper's Avatar
4.10 won't be a real big difference.
410customs likes this.
79jasper is offline
post #10 of 18 (permalink) Old 01-25-2017, 04:42 PM Thread Starter
Garage
last 2 tanks
tank 1 either 15.2-15.5
tank 2 either 16.2-16.5
All 3 fills at the same station and pump.
I put a new fuel filter in before tank 1. not going to admit last time I did that but the engine was in a different truck last time it was changed.
I drove 51 to 53 most of the time. Trying hard to stay under 2000 rpm. Will run one more tank then drive 55-60 and see if it drops back down.
Fuel filler neck is installed on the flatbed. Not real happy with the results. Using first click it spits out a little fuel on the ground when it shuts off.
Sometimes when I start the truck I have no speedo or odometer for a mile or so. I calculated what the odometer said first then with the estimated additional miles. I have a new vss and harness to install hoping to fix this.
