My MPG - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 12-22-2016, 12:52 AM Thread Starter
My MPG
I took a trip yesterday about 130 miles one way. I went the speed limit 75 and some in town driving (15 miles tops) and got 15.3 mpg. I followed some slower trucks home and stayed between 68-70 mph all highway and got 19.3 mpg. I got just over 18 when I brought it home a couple weeks ago. The only thing I have done to it was put an ARE cold air intake on. This is a 2002 F250 4x4 EC SB 7.3 296500 miles. I was told it was all stock but the transmission has been worked on. I went to service it and after spinning the torque converter several times, found there was no drain plug. It sucks for me because I wanted the serviceability of the '02 model. This is my first diesel so I am learning slowly.
I was wondering if this converter has something to do with the mileage I have been getting? What converter would be used to replace the stock converter?
Take care.
linewatch is offline
post #2 of 6 (permalink) Old 12-22-2016, 02:01 AM
Because I can!!!
Thatchevyguy's Avatar
Re: My MPG
Mpg sound about right if your on stock size tires with a higher gear ratio. I've gotten 16mpg with 410 gears,35in tires and a 5spd at 75 mph.
97 F350 cclb
7.3 5spd
95 f350 rclb 7.3
02 f350 ccsb 7.3
Thatchevyguy is offline
post #3 of 6 (permalink) Old 12-22-2016, 02:24 AM Thread Starter
Re: My MPG
I have a lot of friends that were very impressed but after reading some of the stickies, I agree with you it is right where a stock truck should be.
post #4 of 6 (permalink) Old 12-22-2016, 10:41 AM
alleged moderator
tjctransport's Avatar
Re: My MPG
is that with the overhead lie-o-meter, or hand calculated MPG?
the overhead is notoriously wrong, usually reading 4-5 MPG high.
tom
tjctransport is offline
post #5 of 6 (permalink) Old 12-23-2016, 05:51 AM Thread Starter
Re: My MPG
I do not have the lie-o-meter in my truck. It is all stock except for the intake, tires included. It was all hand calculated. Unless the odometer is bad, the numbers are good.
Sent from my SAMSUNG-SM-G870A using Tapatalk
post #6 of 6 (permalink) Old 12-23-2016, 05:53 AM Thread Starter
Re: My MPG
I have also found that after 8-02 the torque converter had no drain.
