Re-gearing - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 24 (permalink) Old 08-30-2016, 04:13 PM Thread Starter
Re-gearing
I have a 1997 f350 f350 Long Bed, Crew Cab, Automatic, 2wd
Have an Edge Evolution programer
4.10 gears and 5.8 mpg
I was wondering what kind of speed and milage differences I would see if i put in 3.73 or 3.55 gearing. What would yall sugest. Thank you
Pwieding_97 is offline
post #2 of 24 (permalink) Old 08-30-2016, 04:21 PM
Moderator
Sbluke55's Avatar
Re: Re-gearing
You have more problems than just gearing if your getting 5.8 mpg.
What mileage are you at?
01 f-250, Standard
Sbluke55 is online now
post #3 of 24 (permalink) Old 08-30-2016, 08:31 PM Thread Starter
Re: Re-gearing
Truck has 75k on it. And I drive like an 80 year old man so its not the way i drive thats causing the issue
post #4 of 24 (permalink) Old 08-30-2016, 08:43 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
Re: Re-gearing
wow, that's pretty rough! are you getting 5.8mpg whether you are running the egde programming or stock program?
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
my farts are so bad, they have been banned in 37 countries!
Turd-250 is offline
post #5 of 24 (permalink) Old 08-30-2016, 08:53 PM Thread Starter
Re: Re-gearing
It gets the same no matter what stock to 100hp settings
post #6 of 24 (permalink) Old 08-30-2016, 10:39 PM
Moderator
Sbluke55's Avatar
Re: Re-gearing
Make sure your ebpv is open all the way. Make sure you don't have brake drag. Check for leaks in your up pipes. Boost leaks.
01 f-250, Standard
post #7 of 24 (permalink) Old 08-30-2016, 11:45 PM
s10mike's Avatar
Re: Re-gearing
yeah, something is fked up there. i would check the brakes like sbluke says. thats waaay bad fuel mileage. my ccsb 4wd with 35 inch tires gets 13-14 mpg
s10mike is offline
post #8 of 24 (permalink) Old 08-31-2016, 02:14 AM Thread Starter
Re: Re-gearing
I unplugged my ebpv and got maybe a .5 increase. My brakes aren't dragin and if there was a leak in the up pipes or a boost leak, wouldn't it be pretty loud cause the truck sounds normal to me. Any other ideas? 😂
post #9 of 24 (permalink) Old 08-31-2016, 02:20 AM
Moderator
Sbluke55's Avatar
Re: Re-gearing
Boost leaks and up pipes won't make a lot of noise.
The ebpv maybe stuck shut and unplugging it won't do anything.
What are you using to track your mileage? You might want to try comparing your odometer to a GPS.
01 f-250, Standard
post #10 of 24 (permalink) Old 08-31-2016, 02:29 AM
Moderator
Sbluke55's Avatar
Re: Re-gearing
Also check for a fuel leak.
01 f-250, Standard
