milage mods - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 12-04-2009, 09:02 PM Thread Starter
<--losser
fordbidden's Avatar
milage mods
what are the best mods for milage. i know driving smart is a key but there must be something that can be upgraded to help this. all and any imput is wanted
F-250 7.3L 2wd manual 5 speed, turbo, chip, custom exhaust
fordbidden is offline
post #2 of 22 (permalink) Old 12-05-2009, 01:15 PM
SD26's Avatar
Re: milage mods
I'll start you off with:
What are you driving exactly? And what conditions do you drive in?
Dave
2005 E350 6.0PSD
2003 Excursion Limited 4WD 7.3PSD - Sold
1996 E350SD dually 7.3PSD - Gone!
2002 VW Jetta TDI - stock
2007 Escape Hybrid
1999 Kaw KLR650 - 17/42 gearing
SD26 is offline
post #3 of 22 (permalink) Old 12-05-2009, 02:50 PM Thread Starter
<--losser
fordbidden's Avatar
Re: milage mods
we have two trucks, a 1988 idi, which has no hope of great milage. the other is a f250 7.3l, 2wd, it has a lame bully dog chip in it, but my dad did that before i could stop him. thanks for the start
post #4 of 22 (permalink) Old 12-05-2009, 03:20 PM Thread Starter
<--losser
fordbidden's Avatar
Re: milage mods
its also rather flat here in that space between illionois and indiana
post #5 of 22 (permalink) Old 12-05-2009, 03:34 PM
I know nothing...
joedaddy's Avatar
Re: milage mods
I'm surprised at what you said about the IDI. My Crew Cab dually 92' got between 16-18 city hiway w/4.10 gears and 7400lbs. The best my stroke has done was 16 hiway. And now that it's running right and I can't stop running to 80 at every stop it's more like 12
I guess the best advice I have is leave it alone because it's "too much fun to make it run!"
Doesn't roll with anyone or tag along to be cool...
joedaddy is offline
post #6 of 22 (permalink) Old 12-05-2009, 06:48 PM Thread Starter
<--losser
fordbidden's Avatar
Re: milage mods
no this one has some issue, we cant get her to shift our of second gear, and its only a three spead, and its NA she doesn't get any driving time haha
post #7 of 22 (permalink) Old 12-06-2009, 12:10 AM
peterbilt'in
Rob02F350's Avatar
Re: milage mods
fix up the idi... get your self some WMO, Filter it out, and mix it in with #2 depending on temp conditions. Tripple or more your MPG#2
other then that, lot of guys use 2 stroke oil in the diesel... new thread started about Sulpher substitute, i just bought a bottle today and dumped it in... but with the ps antigell and some 2 stroke so who knows if my mpg will move.
loose any weight you dont need from the truck, tires to 80 psi, probably ditch the bully dog, intake & exhaust, fluid's...
do some searching...i know you will find a lot of other information
2002 F350 extended cab XLT, 4x4 auto,194K mi @ 10/25/13, ELF7405, DP F5, ultra light gauges, all kinds of "improvements" Yukon Grizzly locker 6K helper springs, x code fronts. 2 Y2K jetta Tdi. RC2 tuned
Rob02F350 is offline
post #8 of 22 (permalink) Old 12-06-2009, 01:43 AM Thread Starter
<--losser
fordbidden's Avatar
Re: milage mods
all right then, that was supper helpful thank you. do you have any other suggestions?
post #9 of 22 (permalink) Old 12-06-2009, 03:33 AM
oil burner
tughill283's Avatar
Re: milage mods
unplug the clutch for the air conditioning compressor
96 f250, ZF5,160cc,
300k miles
96 f350 plow truck
tughill283 is offline
post #10 of 22 (permalink) Old 12-06-2009, 10:38 PM Thread Starter
<--losser
fordbidden's Avatar
Re: milage mods
what does that do?
