New Tire Size +/- MPG? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 12-16-2007, 06:59 PM Thread Starter
War Pig
Caballo Diablo's Avatar
I am currently running 305/70/16D Fun Country IIs, the specs are: 33x12.3, 56 lbs, . I'm wanting to go with 295/75/16D Terra Grapplers, specs: 33.19x12.13, 59 lbs., 626 revs per mile. Will I see any change in MPG? Plus or minus? If need be I'll go down to a 285/75/16E, specs: 32.76x11.5, 58 lbs, 634 revs per mile...i think. I'm thinking the change to a less agressive tread pattern and narrower tire will off set the 1/4 inch height and 3 lb weigt increase netting me a little better MPG.
Chad
04 F350, CC, LB, 4X4 Fat Bottom Girl....Butt A$$ Stock
SOLD>>>'00 F250, DP-Tuner, 5" Straight Pipe, S&B intake, autometer, Racer X TC and VB, Full Force Stage 1, prepump/in-tank mod, Annihilator, 203*
ET: 5.024 250' Mud Track
Caballo Diablo is offline
post #2 of 2 (permalink) Old 12-17-2007, 01:37 AM
MPG Moderator
Dave Whitmer's Avatar
Re: New Tire Size +/- MPG?
Going down to 285 from 305 will improve your MPG. Going to a less agressive lug pattern will improve your MPG.
After changing the tire size, do yourself a favor and get your speedo recalibrated for the tire size you have decided on. Otherwise discussion of MPG is just babble corrupted by speedo error.
2000 F-350 SC 4x2 6 speed
Slammed 4"
Rugged Air Dam
315,000 miles
Dave Whitmer is offline
